Pulled codes and got a 676 - transmission in malfunctioning in 1st gear and reverse. As sad as it is considering that I bought this car not too long ago, I was wondering what the next step would be. Thanks.
I did that the first time I scanned my '93 as I was only used to two digit codes the three digits had me confused at first untill I looked in my manual and learned that '91 up have 3 digits '90 down have 2 digits. Also on an '86 mustang the only trannys availiable were the T-5 and the AOD neither of which are electronic. So basically there ARE NO transmission codes for fox body mustangs at all, except for the neutral safety switch failure which is a code 67.SNAKEYES86GT said:i stand corrected...well then its got to be either a 67 or 76 correct? the first one has something to do with the A/C...and my car doesnt have ac...could that just the the comps response?
SNAKEYES86GT said:*cant -shift into reverse unless i put it in second
SNAKEYES86GT said:well heres the thing...there was a 6 then a 7 then a six without pause...i looked it up in the book from the actron code scanner that i have and 676 says what ive posted previosuly. im just wondering what to do about the problem...i dont wanna argue about whether the code exists or not. Anyways, I can shift into reverse unless I put my car in second or it grinds horribly, and when i let off the gas in first it brakes so much my head flies forward. Obviously the problem matches the code i scanned, looked up, and posted here. If you want to offer help, not argue about the code which is completely irrelevant, I would appreciate it.
