Pulled off upper window trim..
  • Thread starter Thread starter BlownStangGT
  • Start date Start date Jul 8, 2005
BlownStangGT
REPEAT
3,860
Lancaster, PA
Jul 8, 2005
  • Jul 8, 2005
Ok I pulled off my upper window trim and when I took it off there was alot of black sticky stuff that looked like a greese/silicon...is that what it is? I assume its there to keep water out/help to hold the piece in place. I took it off to paint it because it was fading alot. What should I do with it when I put it back on, do I need more or what. Thanks
Rick 91GT
Mustang Master
95
99
PA
Jul 8, 2005
  • Jul 8, 2005
Only nasty black sticky stuff that is under the molding normally is Butyl Tape, windsheild adhesive. (this holds the glass in place and seals out the moisture)
BlownStangGT
REPEAT
3,860
Lancaster, PA
Jul 8, 2005
  • Jul 8, 2005
yup thats it...its really gross anyways, do I need to do anything when I put it back on all freshly painted
mustangjoe87
364
Harrison Twp., Michigan
Jul 8, 2005
  • Jul 8, 2005
which window were you working on? if it is the windsheild have a glass guy come and put it in with urethane windseilds are structural components in unibody cars and butyl tape gives you no strength. however it is ok on the rear hatch window, quarter windows, and tail light lens'
BlownStangGT
REPEAT
3,860
Lancaster, PA
Jul 8, 2005
  • Jul 8, 2005
its the pas/driver side windows, the modling that goes above them that can be taken off with one screw near the front of the windows
mustangjoe87
364
Jul 8, 2005
  • Jul 8, 2005
oh, ok i thought you meant something else. those clean it off with wax and gease remover and then reapply butyl tape before you put it on
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Brake pad and rotor upgrade
  • Sparky714
  • Aug 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 17, 2026
Sparky714
2000 GT-Front Brakes Not Releasing
  • stormsedge
  • Aug 7, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 7, 2026
Bronco2fan
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
