Pushord and Engine Questions?
wild50gt
51
nj
Pushrod and Engine Questions?
i just had a couple questions before i put everything back together... my setup is: F cam, stock 302 bottom end with TFS pistons, TW heads, and FRPP roller lifters. now will i have any problems running 6.75" pushrods which were recommended to me by a couple guys online? also will i be able to get away with my 1.72 Scorpion roller rockers or will i have to use 1.6RR? now if it is possible can i do a step up system with 1.6 intake and 1.7 exhaust? thanks in advance for any help!
-terry
Push rods NEED to be the correct length for the rocker geomerty !!! AFTER the correct geomerty for the rockers is obtained.. THEN check the P/V issues!! you HAVE to have the push rod length correct.. cant play with that...cool??
Just me........................
