  • 1994 - 1995 Specific Tech
Pushrod Length Checker
  • Thread starter Thread starter ShiftTheDrift
  • Start date Start date May 10, 2005
ShiftTheDrift
365
Bakersfield, CA
May 10, 2005
  • May 10, 2005
I bought a push rod length checker from TrickFlow and have no idea how to use it? I mean, from what points do you measure? The rockers are obviously off so...
Anybody know?
final5-0
Mustang Master
Apr 6, 2003
6,817
12
79
DFW Texas
May 10, 2005
  • May 10, 2005
You might wanna take a look at some of the big cam sites like Crane, Comp, etc cause they used to have very good tech articles with really nice pics and diagrams showing how to use pr checkers, degree wheels, etc.
Later
Grady
2L8ULUZ2
Will kiss Moderator ass for title
3,033
14
99
WNC
May 10, 2005
  • May 10, 2005
You will need to measure it from tip to tip, or at least that is how I had to measure my crane cams length checker and that worked. I also used a good set of dial calipers to make sure that the measurement was as exact as possible.
GTJake
3,049
Ann Arbor, MI
May 10, 2005
  • May 10, 2005
Robbie!! Woah...long time no see. How's the long rod motor?
Jake
2L8ULUZ2
3,033
14
99
WNC
May 10, 2005
  • May 10, 2005
Jake
Yea been a little busy. The motor is holding up just fine and considering laying the spray back to it.
Vipersix
434
Clarksville, TN
May 12, 2005
  • May 12, 2005
If you bought the type that is simply an adjustable pushrod then here's how to get it done.
Install the rod checker with heads on and loosely install the rocker. Turn the crank until you begin to get pressure from the lifter. Once you get pressure, adjust the checker as necessary until the rod mates correctly with the rocker. If you have adjustable rockers this is immensly easier. Rotate crank again until valve is completely closed and ensure there is no slack in the rod, if there is adjust the rod until it's gone. Rotate crank once more to ensure proper placement of rocker on rod and correct movement of the valve from completely closed to completely open. The closer you get to true on a non-adjustable rocker setup the better you'll be. The same is true of an adjustable setup but you have the benefit of some room to play with. Once you are sure of the length, measure the checker and order your rods!
That's it in a nutshell.
M
Pushrod length
  • mattcrp1
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 4, 2025
mattcrp1
M
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
J
Exhaust manifold to Y-pipe nut & stud dimensions?
  • joeybuddy96
  • Jul 7, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jul 9, 2026
joeybuddy96
J
T
408w pushrods
  • Towegage
  • Sep 19, 2025
  • Fox Engine Swaparoo
Fox Engine Swaparoo Sep 19, 2025
A
Valvetrain help
  • Angelq1028
  • Dec 20, 2024
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 21, 2024
limp
