Pushrod Length Checking Lifter
  • Thread starter Thread starter Ocalafox
  • Start date Start date Oct 14, 2008
O
Ocalafox
266
sunny central FL
Oct 14, 2008
  • Oct 14, 2008
Guys, please verify that I did this correctly. I took 2 stock roller lifters, removed the spring retainer and plunger. I filled the bottom cavity of the lifter with small nuts (1/4") and a washer then reinstalled the plunger and spring clip (real tight fit). Will this remove any compression from the lifter when checking pushrod length? Also, are the lighter springs required when using an adjustable push rod tool?
Thank you, vann
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Oct 14, 2008
  • Oct 14, 2008
you should have just left the lifter alone and used a test spring. they dont have enough pressure to compress the lifter. imo
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Oct 14, 2008
  • Oct 14, 2008
That's another way to do it, but if you don't like removing springs (or don't have the tools for that matter) it's a lot easier to do what he's doing.
A word of caution, don't rotate the engine with the length checker in...it'll snap. It isn't strong enough to withstand the force of the spring when you turn the engine over.
G
Engine Pushrod Length Question
  • germain101
  • Sep 22, 2025
Fox 5.0 Mustang Tech Sep 25, 2025
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
M
Pushrod length
  • mattcrp1
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 4, 2025
mattcrp1
M
Y
Engine Oily cylinder- bad lifter relationship
  • Yoyoda
  • Nov 9, 2024
Fox 5.0 Mustang Tech Nov 16, 2024
Yoyoda
Y
Engine Valve and or rocker noise .....new to this but dont mind getting my hands dirty.
  • mustang matt 1993
  • Jun 29, 2024
2K
Fox 5.0 Mustang Tech Jul 1, 2024
rednotch
