Engine Pushrod Length Question
  • Thread starter Thread starter germain101
  • Start date Start date Sep 22, 2025
G
germain101
14
Odessa, Fl
Sep 22, 2025
  • Sep 22, 2025
Just need a little sanity check. Changed out heads for a new set of aluminum ones with roller rockers. Put in a solid lifter and used my adjustable pushrod to get the tip centered on the top of the valve stem and then tightened the poly lock finger tight to take the slack out. Turned the engine over a few times and got a real nice mark dead center on the valve that is about .080" wide. Measured the push rod and it was 6.26" long.
What I'm concerned with is the pre load. I know some people tighten the poly lock 1/2 a turn when measuring the push rod length with a regular lifter and a checker spring, but I wouldn't imagine doing that with a solid lifter. I've also heard people say you need add .050" to your measurement when using a solid lifter to acount for the lifter preload. Where im getting hung up is, how much am I supposed to tighten the poly lock if I order a set of pushbrods that are .050" longer than my measurement? Or am I doing something wrong?
AeroCoupe
6,243
4,334
183
Claremore, OK
Sep 22, 2025
  • Sep 22, 2025
My understanding with a solid lifter in place on a cold engine is to adjust the pushrod for zero lash. Remove the pushrod and measure. That is your final length. Lash is set on a hot motor with your zero lash measured push rods. Warm the motor up and then adjust your rockers with the camshaft manufacturer’s hot lash spec. Rinse and repeat for each cylinder but make sure the motor is at or close to operating g temp.
G
germain101
14
Odessa, Fl
Sep 22, 2025
  • Sep 22, 2025
Yeah, sorry for the confusion. I was just using the solid lifter to measure my pushrod length. I'm actually using hydraulic roller lifters to run the motor.
My problem is I'm not sure how much to add to the measured pushrod length and how much do I tighten the poly lock down after zero lash.
AeroCoupe
6,243
4,334
183
Claremore, OK
Sep 22, 2025
  • Sep 22, 2025
In this instance you go to zero lash and that’s it. Order the push rods, install new push rods, take to zero lash, then 1/4-1/2 turn past zero lash, and then set the poly lock.
nicholase
I lubed and pushed, until it was all the way in
May 21, 2024
670
1,196
103
New York
Sep 22, 2025
  • Sep 22, 2025
Yup. Just make sure the soild lifter is exactly the same measurement (inside of pushrod cup to roller tip) as the one your going to use. Probably pointing out the obvious.
Reactions: Blackhawkxx
G
germain101
14
Odessa, Fl
Sep 22, 2025
  • Sep 22, 2025
Ok, so no need to add any additional length for lifter preload to my measured length? At zero lash (finger tight) and solid lifter for measurement, my pushrod length is 6.26".
I've got 3/8 studs which have 24 threads per inch. That gives me .042" per turn. If I give the poly locks 1/4 to 1/2 turn, that's about .011-.021" of preload on the hydraulic lifter. Just wanted to make sure I don't have to add anything extra to my measurement for preload. Thank you for the responses, its very much appreciated. Just want to make sure I get this right.
nickyb
I gotta say i never painted my nuts, Never Ever
3,063
1,679
163
nevada
Sep 22, 2025
  • Sep 22, 2025
Stop trying to add length to your rod.
It is what it is.
Reactions: Noobz347 and nicholase
Admin Dude
Jan 4, 1985
43,565
21,736
234
Box behind Walmart
Sep 22, 2025
  • Sep 22, 2025
It is what it is.
I been doing it that way since ruler class in kindergarten.
Reactions: AeroCoupe
AeroCoupe
6,243
4,334
183
Claremore, OK
Sep 22, 2025
  • Sep 22, 2025
Sounds like you need a stock length 6.25” push rod.
G
germain101
14
Odessa, Fl
Sep 22, 2025
#10
  • Sep 22, 2025
  • #10
I think I just need to measure from underneath. I hear it's longer that way.
nickyb
3,063
1,679
163
nevada
Sep 22, 2025
#11
  • Sep 22, 2025
  • #11
No no no, balls don't count.
General karthief
Mod Dude
Aug 25, 2016
28,135
10,755
213
polk county florida
Sep 25, 2025
#12
  • Sep 25, 2025
  • #12
Push rods have balls?
Admin Dude
Jan 4, 1985
43,565
21,736
234
Box behind Walmart
Sep 25, 2025
#13
  • Sep 25, 2025
  • #13
Rocker arms have balls.
Reactions: Mcmahst
M
Pushrod length
  • mattcrp1
  • Sep 1, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 4, 2025
mattcrp1
M
Engine Finishing up 331 build
  • RedFury5.0
  • Mar 21, 2025
Fox 5.0 Mustang Tech Apr 20, 2025
RedFury5.0
Engine Valve and or rocker noise .....new to this but dont mind getting my hands dirty.
  • mustang matt 1993
  • Jun 29, 2024
2K
Fox 5.0 Mustang Tech Jul 1, 2024
rednotch
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
Resolved Noisy Valvetrain
  • PonyGTrider
  • Jun 15, 2024
5K
Fox 5.0 Mustang Tech Jun 19, 2024
PonyGTrider
