got my afm mr freeze boost cooler kit in and pured in 50/50 methanol/distilled water. it make take advantage of the cooler intake charge i took off my 3" pulley and put on a 2.75" i used to get 9psi of boost no i get 4psi. what the hell happened? i also lost hp. i can see the hp loss because im not done tuning, probably have to have the dyno tuner do it cause i have the fp set at 42psi getting a 10.5:1 afr which is close to what my tuner set the afr to when i ran the 3" pulley so afr hasnt changed much but i lost boost and power.(he had it set to 10:1 for some conservative reason) the belt is tight and i dont hear any slipping. why did i loose boost with a smaller pulley?
