  • SN95 4.6L Mustang Tech
Puting in sportlines myself...
  • Thread starter Thread starter steelcitystang
  • Start date Start date Apr 21, 2005
steelcitystang
Washington, PA
Apr 21, 2005
  • Apr 21, 2005
Anyone out there put in lowering springs yourself? Is there anything I should need to look out for? Anyone run into any problems? How long do you think it'll take? Any advice? Thanks
Can't wait to get rid of that 4 X 4 look!!!
streetstang03
unModerator
Dec 27, 2003
the dark side of the moon/home of the 1999, 2003,
Apr 21, 2005
  • Apr 21, 2005
http://www.mustangworld.com/ourpics/fcar/steedaspring1.htm
http://www.stangnet.com/tech/spring.html
Joltergeist
50
Northern VA
Apr 21, 2005
  • Apr 21, 2005
Did the full Steeda G-Trac 1, 2, 3 in my little garage... my only 2 suggestions, Impact tools and a Spring compressor. I did mine without the impact tools, and it took much longer than it should have.
GDawg
1,469
Nevada
Apr 21, 2005
  • Apr 21, 2005
Be sure the rear spring pigtails are facing the correct direction. (toward the drivers side of the car for both of them)
sixstang
27
  • Apr 21, 2005
Easy to do, a friend will help but isn't necessary.
KAILUAZ
333
St Pete, FL via Kailua, HI
Apr 21, 2005
  • Apr 21, 2005
Pretty straight forward, took me, myself and I about 2 hours.
40thGT
14
Jupiter, FL
Apr 22, 2005
  • Apr 22, 2005
Not bad at all, did it with hand tools, no spring compressor. Less that 2 hours. The only suggestion is to lay the frame on jack stands, support the lower control arm with a good floor jack and when all the nuts and bolts are out, SLOWLY lower the jack, once it's all the way down the pressure is off the spring, use a pry bar or tire iron to pull it out. The Rear is alot easier.
69fb00GT
117
Southwestern PA
Apr 22, 2005
  • Apr 22, 2005
He has no friends.
mity2
I like Pro3 and all I got was this crappy CT.
Jul 24, 2003
2,872
StateCollege PA
Apr 22, 2005
  • Apr 22, 2005
rear is cake.u don't really need spring compressor either. unbolt shocks, quad shocks, let alxe hang down. u'll have all the room u need. then front is bit more tricky, due to more components that'll have to be removed, but still straight. I'll get spring compressor for the front tho
DELOS02GT
461
Naperville, IL
Apr 22, 2005
#10
  • Apr 22, 2005
  • #10
You got that right!! I didn't pay attention to that and had to do the rears all over again. It's not a hard job, but I had a lift and air tools. It took us about 45 min and we were done. If I had to do it in my garage it would have taken a lot longer.
ninety15.0
1,336
#11
  • Apr 22, 2005
  • #11
Me and my friend did the entire suspension on both our stangs in about 4 hours in a parking lot at school with just handtools. We changed all struts and shocks too. U dont need a spring compressor.
MNDZA
Banned
Apr 21, 2004
57
Chicago
Apr 22, 2005
#12
  • Apr 22, 2005
  • #12
It's an easy job. Just make sure to get two friends to help. One does the actual work, another does the supervising, and the third gives moral support while drinking some cold beer.
69fb00GT
117
Southwestern PA
Apr 22, 2005
#13
  • Apr 22, 2005
  • #13
MNDZA...that is the sweetest avatar EVA!!!
A
A/F ratio gauge install questions.
  • AngryH58
  • Sep 24, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 22, 2026
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
  • 2000xp8
  • Jul 9, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 18, 2026
AeroCoupe
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
J
Suspension Foxbody mustang Steering shaft issue
  • Jakub2537
  • Sep 5, 2026
Fox 5.0 Mustang Tech Sep 11, 2026
gkomo
