BlackVert
looks pretty ghetto, but if it works, thenHink said:Here is the bottle side view so you can see bottom part of the Aluminum bottle setup.
Enjoy,
Hink
vristang said:Hink -
I am having a hard time visualizing how this modified screen will help.
Are you not using a baffle on the lower intake?
There should be a baffle there, installed by whomever manufactured the manifold.
Are you installing this is the stock screen location?
I am just having a hard time seeing how these washers will help separate oil from the air.
Maybe I missed something?
jason
TheBocSez said:Also, is the PCV valve tapped directly into the VC? if so, how does this prevent oil being sucked up through it? The PCV valve would seem to be closer or at least as close to an oil source with the rocker arm flinging it all around. Wouldnt it stand to reason that if your VC to TB hose can suck oil all the way up the filler neck, that the PCV could suck oil up too?
slvrvert91 said:Ironically I have just discovered that I am leaking oil at a good rate. It looks to me as if the oil is coming from the rear of the intake. Could it be a gasket? If not what is the easiest way to fix this? If I remove the PCV filter and it is clogged is that my problem? Thanks for your help
$uperstang said:Boc I have the tall Ford Racing valve covers with baffles under both valve covers all the more reson I probably do not get much oil coming out of their. And yes it is set-up exactly as you have described in the previous post, I will take some pics it's real simple and works but If you don't have baffles under the vlave covers it will suck oil still. I'll take some pictures!
Nicoleb3x3 said:is it ok to plug the pcv screen (delete it entirely) and vent using a breather on the valve cover?
my car is not modified, it's only stock
should I be ok? or what???
$uperstang said:OK guys check my cardomain site for recent pics: any questions just ask. It's really as simple as it look. PCV in rear of intake plugged, PCV in driver side valve cover, hose routed under the intake to the rear where it goes in to the oil seprator and then to the upper intake, DONE!
http://www.cardomain.com/ride/2188563/3
vristang said:Are you using an intake manifold spacer?
vristang said:![]()
Just wondering how this fits with a stockish setup.
Well, done.
jason
