Putting together a 408 stroker for a 94-95 sn95 car. Need some input.
Luis Ceballos
Well as the title says im going to be building a 408 stroker and thinking of putting it on a sn95 body incase a cheap fox does not come thru. The base for this is a 89 block out of a bronco , will have the block inspected and bored 30 over . As for the stroker kit I will either piece it together or get one from scat or eagle, I decided to go with a budget septup because this will not be a high HP car, no force induction. I already have my twin turbo coyote car for that. Okay so cast crank, forged rods and hyper pistons that's what most of the cheaper kits consist off. It may see nitrous but not much, 100 hp shot at most. This gonna be a fun project and really something I been wanting to do for a long time. Im one of the few that just love a well done SN95 car.
Okay now onto the part were I would like some advice, Heads and intake options, I dont want to really cheap out on this part because if anything the top end is whats going to decide how much power and torque I get from this engine. I want to know what size heads would best fit a 408, I have been looking at the edelbrock e-series cylinder heads. The price on these heads is just right in my budget, another is the victor Jr heads. My main concern is the heads, I dont want the wrong heads on the engine that would be too small and choke it out, im looking to make close if not more than 430 rwhp on this setup. For intake I have been thinking of using a carb style lower with bungs for injectors like a dual plane style manifold with an elbow and matching throttle body for an engine this size. Car will be auto with 4.10 gears . What do you guys think of this combo ? Around 10/11 to 1 compression ratio.
  • Sponsors(?)
jrichker
StangNet's favorite TOOL
SN Certified Technician
Mar 10, 2000
27,362
2,825
234
74
Dublin GA
lowendmac.com
225 cc heads, don't cheap out and buy Chinese fried rice heads. You're going to have so much torque with a properly built and tuned engine that 4:10 rear gears are going to be too much. All smoke and no traction and you'll probably run out RPM before the finish line. Turning a stroker past 6400 without an exacting and expensive balance job is not a plan for long lived success.
Luis Ceballos
I have been looking at the edelbrock e-series heads, 205cc runners , 60 cc combustion. What do you think about this head ?
Davedacarpainter
I think I've messed my pants
Nov 28, 2015
11,891
11,344
193
57
Discordia
Nothing wrong with Edelbrock, BUT, AFR 220’s or even better yet a set of Trickflow high ports will net you more. 10.5 to 1 compression will make a sweet engine for you.
I’m not bashing Edelbrock, but AFR and especially Trickflow heads are what’s hot at the moment.
Luis Ceballos
Gonna have to break out the wallet for those, but you are right, its one of those things were if I get the edelbrock and make xxx amount of power and the find out those other heads would have put me way above my goals. What are you guys opinion on how much Horsepower and torque a 408 with a combo like that should be putting at the tires?
Davedacarpainter
Nov 28, 2015
11,891
11,344
193
57
Discordia
Reactions: General karthief
Luis Ceballos
Nice choice, though a 408 could easily use AFR 220's as well.
What are other choices that compare to afr 205 and 220s? I know I mentioned the victor jr heads, do they perform similar to the afr 205s or 220s ? Trickflow ? I get on summit racing and I see other brands aswell as cast iron heads from dart and so on, any experience with those other heads ?
Davedacarpainter
Nov 28, 2015
11,891
11,344
193
57
Discordia
I know about the AFRs, though the drag racing guys here say the Trickflow high ports are clearly better. Truthfully, they would know best there I think. @TOOLOW91 has more real knowledge about them than I do.
There’s nothing wrong with the victor jrs, they are good heads. Just not on the same par as AFR or TF.
I got nothing on the Dart heads for you.
TOOLOW91
7,116
234
S.I.NY
Starting from scratch id be looking into some high ports for sure . They are on par if not better then the AFR 220 renegades . All depends on what you’re goal is with the Car though . Vic JR are killer heads ported as we’ll . I have multiple friends who have been deep in the 8s with them
Thread starter Similar threads Forum Replies Date
Mstng93SSP Putting my engine together 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 42
Hoytster Progress Thread Darn Stock Block Problems - Putting together the pieces Fox 5.0 Mustang Tech 53
T I Need Help Putting Tragically Modded Car Back Together 1996 - 2004 SN95 Mustang -General/Talk- 5
billison Putting The Engine Harness Back Together Fox 5.0 Mustang Tech 7
The Green GT Getting Ready To Put The Engine Back Together. Quick Question. 1994 - 1995 Specific Tech 6
mike arntson Putting New Car Together And Need Some Advice. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
D Need Some Help Putting Together My 50 Fox 5.0 Mustang Tech 1
SaleenS281GT Putting Together Engine SN95 4.6L Mustang Tech 4
J Putting an engine together! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
J Putting an engine together! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
SLYFOX89 !!!PLEASE HELP ME PUT THIS TOGETHER!!! Fox 5.0 Mustang Tech 13
S Putting my 1990 together after years off! Fox 5.0 Mustang Tech 0
wiski Time to put her back together Fox 5.0 Mustang Tech 2
P I have a feeling it will take longer to put back together Classic Mustang Specific Tech 6
silver1983gt5.0 question before I go further in putting my engine back together Fox 5.0 Mustang Tech 17
white nite Putting her back together...slowly 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 24
W putting together a auto 95 roller. 86 stick 347 going in 1994 - 1995 Specific Tech 9
lincoln+ford Ok im putting together a cheap 302 Fox 5.0 Mustang Tech 6
T step by step on how to put rear end back together Fox 5.0 Mustang Tech 8
P How to put together an interior with a 8-point cage??? Classic Mustang Specific Tech 3
2 put my t5 back together new issues Fox 5.0 Mustang Tech 2
scupking Putting a supercharger together SN95 4.6L Mustang Tech 5
Pokageek What was Ford thinking when they put together the rear suspension? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 16
S putting car back together, have a couple questions Fox 5.0 Mustang Tech 1
daviszx3 New Pics: painted and back together,lowering springs just put on 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 23
R If you had to chose manuals to put a car together... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
allcarfan Putting Together Fuel system Classic Mustang Specific Tech 24
G Small Video I put together 1996 - 2004 SN95 Mustang -General/Talk- 6
Aliate X Short incar vid I put together, TFS top end kit... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 17
N Finally putting my car back together... question about my setup... Fox 5.0 Mustang Tech 3
89RedFoxGT Putting my motor back together, anything important? Fox 5.0 Mustang Tech 1
03v6 A little something I put together... 1996 - 2004 SN95 Mustang -General/Talk- 5
Mustang5L5 Putting together an in-car tool kit + other necessary items 1996 - 2004 SN95 Mustang -General/Talk- 26
M "Mustang: The Unexpected" : a "commercial" I put together 2005 - 2014 S-197 Mustang -General/Talk- 3
0 Need To Fing Torq Specs To Put 5.1 Stroker Together!!! SN95 4.6L Mustang Tech 9
SVT-Sinister Can someone put this together for me 2005 - 2009 Specific Tech 0
J Motor feels sluggish after being put back together Fox 5.0 Mustang Tech 7
FastA$$89Vert Put motor back together...WONT START Fox 5.0 Mustang Tech 26
T Heeeeeelp!!! Trying to put a 94 back together. 1994 - 1995 Specific Tech 14
jasonn How do you put -an fittings together?? Classic Mustang Specific Tech 6
N Quick advice before I put my engine back together Fox 5.0 Mustang Tech 4
Wil how to put center console together?? Fox 5.0 Mustang Tech 3
BlueOvalStangGT Just finished putting the car back together and it wont start......Starter???? 1994 - 1995 Specific Tech 6
final5-0 I put together a Small Site 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
ImportEater98 Help me put together a carburated setup! Fox 5.0 Mustang Tech 15
Mavrick Putting a motor together.. any tips? Fox 5.0 Mustang Tech 2
S Put Together Engine, NOT STARTING!!! Fox 5.0 Mustang Tech 15
Chowder Head Put together a great X pipe, long tube header combination for me please.... Fox 5.0 Mustang Tech 8
BlueOvalStangGT Can I just put this shortblock back together and then put it in my car? 1994 - 1995 Specific Tech 1
BlueOvalStangGT Can I just put this shortblock back together and then put it in my car? Fox 5.0 Mustang Tech 23
