pvc valve poping out
steve75
12
im running a novi 1000 with 5lbs of boost. the pvc valve is poping out of the intake every time i get all over the car. is this a common problem? ive done a search but havent found much. what can i do to fix this problem?
do you have your hose still on from your valve cover to your throttle body? This will boost your crankcase. Your rear main may already be blown, but at least its not high boost so you might be lucky. Using thick grease sometimes helps keep the pcv in. Or a few daps of glue/rtv.
