I am currently in the process of swapping motors.I couldnt get the high pressure hose fitting at the pump broke loose with a stubby wrench, so I applied a little heat,I eventually got the fitting broke loose however the line started to leak fluid after applying heat.when I finally got the line removed there was a plastic washer that was mangled,was that the source of the leak? can I get another one?
