QA1 A-arm and QA1 k-member alignment help
ProjectoStang
80
Happy Holidays to everyone to begin with!
I have had my QA1 front suspension for some time now, and I am starting to put it together. I have QA1 tubular A-arms and the tubular k-member.
The A-arm question is, the front bolt placement fits snug but the back bolt placement there is a space on each side. Is it supposed to be like that? I read that it comes with the bushings so I don't think I'm missing that. I also tried the stock A-arm to see if it fit the same and it does.
I need help sqauring the k-member. Can anyone help me or give a link that shows how to.
thanks
I have the QA1 with the stock A-arms. I didn't use any spacers. I figured the A arm does need some sort of play since the bushing is rubber. My K didn't come with bushings or spacers of any kind. Just becareful when you tighten those bolts because if you overtighten the K member ears will bend and may also break (then your screwed).
