quad shocks neccessary after LCAs?
It's hit or miss with each car. Some cars need them even with aftermarket LCA's.
Even if you didn't need them, i would keep them on. They actually do their job.
IDK, any decent aftermarket LCA is going to be much stronger than the stamped stockers. With a MM part I would not doubt it one bit they are more than ok to do without the quad.
The Quad is more of a factory band aid to make up for how crappy the stock LCA's are to help absorbe the shock/flex of those weak LCA's.
With a poly or solid bushing and a tube structure there is no need.
+1
Really, if they are not rubbing….I’d keep them on. The greatly reduce the chance of wheel hop which can absolutely destroy your torque box’s. I’m actually going to be replacing mine (they are shot) with a new set here shortly before I go to the track with the new rims/tires.
Plus Ford likes to save money. If it was a matter of redesigning some $5 bushings to eliminate some $25 shocks, they would have done it a long time ago rather than putting them on every 86-04 V8 Mustang made (except IRS).
They shouldn't be looked at as a band-aid component, but instead as an important suspension part. If you get LCA's and don't have any tire-fittament issues, don't take them off at all.
I find your avatar so incredibly distracting... I couldn't even make it thru this entire thread. I suddenly though..who gives a poop about lca's. :shrug:
I removed them on my 91 notch and I got wheel hop. Put the LCA and UCA's on and the wheel hop dropped considerably, but didn't stop. I still got a little. I went from BFG KDW tires to some Goodyear ZR45's and the wheel hop completely went away. Sometimes it's in the tire too.
This full-size version of the avatar will make your day (and mine :D).
