First off, I know this topic has been beaten into the ground and i did numerous searched on it. this concerns the dreaded coolant leaking problems i've read so much about and the sh**tty plastic intake manifold.
i've been through the whole loop now.
A while ago the gasket between the thermostat housing and intake manifold blew out and covered the engine in a nice coat of coolant.... so i replaced the thermostat and the gasket. Leak stopped for a while....
Eventually the car began leaking an extremely tiny small amount of coolant in the same spot but nothing huge so i wasnt too worried. THEN after driving home from school one day, i parked my car and returned 5 min later to get my backpack out. I found ALLLL of my coolant in a puddle on the ground draining down the parking lot.
it was the water pump that got messed up when it ran dry because of the first coolant leak, so I replaced the water pump. that specific leak stopped.
The small leak from the thermostat has been bothering me for some time now so i decided to get it checked out and found that the retarded plastic intake manifold is cracked. bang:
Summary:
- multiple coolant leak problems
- intake manifold is cracked and melted
- I NEED A NEW INTAKE MANIFOLD because ford is retarded.
i did numerous searches and found that people have been complaining about the typhoon and then some regarding the trickflow intake and how tight of a sqeeze it is. I need an intake manifold that will work with my accufab tb and plenum. What do you guys recommend quality/fitment-wise??
Summary:
Additionaly, the stock plastic intake manifolds have a tendancy of cracking in the rear as well.
im payin 20 bucks to get it shipped and i'll install it and just wait a couple weeks for the next batch of HPS Hardball'r manifolds.
