Question 302 weight
  • Thread starter Thread starter Gadget
  • Start date Start date May 24, 2004
G
Gadget
36
Montreal
May 24, 2004
  • May 24, 2004
Hi Guys long time reader what can i say great info.
But i cant seem to find the weight of a complete 302 HO.
Also how much dose aluminum heads safe on weight
Im Dropping a 302 into non Ford. So im trying to keep the weight to a minimum.
The stock motor and tranny in there now weigh 572lb
Iv had 8 mustangs this will just be a weekend toy.
Thanks
The Shape
2,224
East ARKANSAS Delta
May 24, 2004
  • May 24, 2004
I don't know the exact weight, but I know it took me, two friends and alot of cuss words to lift and entire 5.0 engine into the back of a silverado.
P
ponyboy302
51
  • May 24, 2004
All i know is that me and a friend took the cast iron heads off the stock 5.0 and those mothers were heavy. It takes 2 hands to hold that thing. The aluminum TFS heads were really easy to hold and took alot less effort. I would say about 40% less.
drgn5.0
603
  • May 24, 2004
you save an easy 40 lbs switching to aluminum heads.
89 droptop
86
Centrial California
May 25, 2004
  • May 25, 2004
I just got a brand new ford 5.0 crate engine with aluminum heads the shipping weight was around 425-450 pounds, and I think I read that the aluminum heads save 40 pounds each, i could be mistaking that for both, but I think it is each because I was pretty suprised.
G
Gadget
36
Montreal
May 25, 2004
  • May 25, 2004
Great thanks Guys. 425-450 sounds good. looks like my V8 swap is going to be close if not lighter then the 4 cylinder and tranny thats in there
G
Gadget
36
Montreal
May 25, 2004
  • May 25, 2004
Did some more searching and i found this
The next weight-saving measure would be a set of aluminum heads. Dan Masters' page that I referenced earlier has his own measured weight for a complete 302 with aluminum heads, manifold, water pump, and all accessories -- and it's only 424 lbs!
and im told the T5 is 75lb without the bellhousing. so ill say 100LB with bellhousing
Not bad 524lb motor and tranny
Thanks again for the help guys
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
J
Help Figuring Motor Choice(Possible future turbo)?
  • jaygee15
  • Dec 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Jarhead67
J
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
Engine 302 production block selection
  • FastDriver
  • May 19, 2024
  • 2 3
8K
Fox 5.0 Mustang Tech Jul 1, 2025
FastDriver
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
