Question about 8.8 rear end
Jul 11, 2007
89
I recently got a use rear out of a 87 t-bird tcoupe for the 5.0, when i removed the diff cover I noticed some surface rust on some of the ring gear and diff gears. Is this a major issue or can I run it like this a the rust be knocked off or what can I do to repair the issue.
thanks
Just get a little oil and a toothbrush and rub it and it should disappear.
First turn of the gears will grind off the surface rust as well assuming it's light surface rust.
