So I am planning to plug RJM EGR Eliminator into my 1990 5.0 Mustang. RJM Injection Tech — EGR Eliminator
I do have the EGR unit still installed but sensor is disconnected from the harness connector.
Does anyone know if I MUST remove the EGR unit and block it off in order to use this eliminator ? or I can simply plug this elminator without removing the EGR unit from throttle body ?
Also, is there any mismatching issue in the 1990 EGR sensor connector that might cause real problems if I am not aware of ? I guess that there are at least 3 pins in the eliminator and in the harness connector... any advice will be appreciated.
