I just turbocharged my 90' coupe. I'm using a 1.27 ar holset Turbo, Tial wastegate. right now it has 2" chrossover pipe and a 3" inch down pipe (which will be changed to 4 soon). The heads are stock, except the valve springs, and they are port matched the the Performer RPM intake manifold. It also has an E cam. I am currently blowing through a Granetelli mass air and using 24 lb injectors, 70 mm throttle body etc... My question is I need more fuel Bad. I am building another motor (306) to take it over 20 lbs of boost, which shooud be good for 600+ hp. This setup is totally new to me, and I would Like some suggestions on what size injsectors, throttle body, and other things I might need. I am planning on pushing it into the mid to low 10s.
Thankyou for any feeback
