Question about Gears and Odometer
  • Thread starter Thread starter sunil6784
  • Start date Start date Apr 17, 2005
sunil6784
620
Boston, MA
Apr 17, 2005
  • Apr 17, 2005
Hi everyone,
I'm going to pick up my mustang tomorrow. Its a 92 LX Special Edition w/ 67,000 miles on the clock. The previous owner has 3.55s in the rear. I'm not sure if he did the speedo gear with it. If he hasn't, then the actual mileage would be less than what the odometer says right? Also, lets just say the gears were done right when the car was brand spankin' new, how off would the odometer be?
MustangMuscle86
24
North Ridgeville,Ohio
Apr 17, 2005
  • Apr 17, 2005
I don't think the speedo gear ahs anything to do with the odometer.
T
tom2001gt
292
Delran N.J.
Apr 17, 2005
  • Apr 17, 2005
When I put 3.55 gears in my car the speedo was off about 15 MPH so the odometer could be off a good bit.
RYC CUKR
1,437
Orlando
Apr 17, 2005
  • Apr 17, 2005
I can't remember if it will be high or low but it will be off if the speedo gear hasn't been changed. Both the speedo and the odometer are driven off of that gear.
Gemini
12
New York
Apr 17, 2005
  • Apr 17, 2005
If the speedo reads high say 50 when you are doing 40 then yes the milage is actually lower by that percentage.
squeeeg
1,905
Michigan
Apr 17, 2005
  • Apr 17, 2005
You are correct. The odometer would read higher then actual miles if he didn't change the gear. Also remember that the odometer could be 167,xxx as opposed to 67,xxx. Just something to keep in mind when buying a fox
87gtconv
ragtopman
2,595
Southern Calif
Apr 18, 2005
  • Apr 18, 2005
my odometer indicates 21,XXX miles and carfax says something is wrong when all it did was roll over a few years ago.
W
Speedometer and shifting issues
  • wyatt-tetro891
  • Aug 17, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 18, 2026
wyatt-tetro891
W
P
Drivetrain 1988 T5 Grinding going into 2nd gear, '92 Camaro transmission swap or parts?
  • pindude80
  • May 7, 2024
  • 2 3
5K
Fox 5.0 Mustang Tech Jun 11, 2024
LILCBRA
Requesting Guidance for 306 motor swap - Fuel? - SD? MAF?
  • So_Flo
  • Jul 26, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 4, 2026
Mcmahst
  • D Durden
  • Oct 20, 2025
  • 2 3
3K
First gear is too tall. Should I make it taller? Nitrous guys, help!
  • FastDriver
  • Dec 30, 2023
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Dec 31, 2023
AeroCoupe
