Question about gettin' head...
hoopty5.0
mechanicus terribilis
7,842
6,990
214
SW Houston
...runner sizes that will work on my 408. (see what I did there? teehee)
Anyway, I found a good deal on some World Products Windsor Sr. Lite 200cc runner heads with 64cc chambers. Without worrying about the compression/size of the chamber, will these heads choke the engine down enough to where I will regret not going with an AFR 205 instead?
My goal is to be in the mid/low 11s in my notch. I wont see too much track time, mostly street, so I am not too worried about top end. Mostly looking for bottom end torque up through the mid range for a fun street car. My shortblock is done, so now its time to look for heads.
Thanks in advance,
Collin
Rick,
I am running an EFI setup, probably going to run a TFS type of intake. Haven't decided yet.
Unfortunately, the heads I was looking at sold pretty much immediately, and before I could figure out if I could use them or not. (wanted $850 shipped)
Probably just going to stick with the original AFR 205/TFS intake/custom cam setup. Might take a little longer to buy, but we all know that that combo is good for making power.
Would you agree?
-Collin
Well normally, I do my engine work, but this time I let teh local machine shop take over the building of this engine. He had a bad experience with a Trick Flow head setup and wants to run AFRs on it instead.
I've been doing a lot of reading on the Windsor Sr. and W.S. Lite heads today. They seem to be decent heads, but turn into great heads once the bowls are worked around a little bit and some mild porting is done.
I read several claims of people that had them on 408s running well into the 10s.
I found another set that has been ported some for a good price it seems. The guy wants $875 for Windsor Sr. Lites with a port job. Says they have been washed/pressure checked/level checked and were good.
What do Yall think? :shrug:
Iv never used them personally, but Iv knew a couple guy thats used them and loved them. There from World Products so you know their good heads. I was thinking bout ventchering out and using TFS but if I can find some WP Windsor Srs for that price, thats the way Im gonna go. Iv never saw the Windsor Sr lites, are they aluminum or something? Sorry I didnt meen that I was gonna try to buy those heads out fom under you, I was curious as to where you can get them for that price.
No worries man. From what I understand, the lites are aluminum versions of the Windsor Seniors. I may not be able to get them, so if you want, I'll PM you the link to the heads. I am having trouble getting in touch with the engine builder to see if the chambers are the right size since I am offshore.
