question about my C4 trans
  • Thread starter Thread starter allcarfan
  • Start date Start date Sep 18, 2004
allcarfan
The Answer Man
2,458
North Atlanta
Sep 18, 2004
  • Sep 18, 2004
I pulled my engine and transmission out together today.
My TCI converter has studs on it that barely fit through the flexplate holes...I mean...TIGHT. well, when I went to go seperate the engine and trans, the torque converter stayed bolted to the flexplate and the transmission came off....with some twisting and turning and coaxing.
So, there I sat with my engine and trans seperated and the torque converter still bolted to the fexplate. well, the center shaft on my transmission...i can pull right out with my hand. I can push it back in, fortunately, i cant turn it or anything like that.
Is that center-most shaft on the C4 suppose to slide out like it does? I cant remember if it is suppose to or not. Could anything have been damaged by the torque converter staying bolted to the engine when i seperated it from the trans? What should I look for?
D
D.Hearne
11,730
south louisiana
Sep 19, 2004
  • Sep 19, 2004
Nothing at all unusual about what you did. That shaft does come out that way. When you put the two back together, take the converter loose from the flexplate first and reinstall it back onto/into the input shaft/front pump.
allcarfan
The Answer Man
2,458
North Atlanta
Sep 19, 2004
  • Sep 19, 2004
phew.
Thanks D
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
F
C4 Transmission
  • Fri Guy
  • Jan 23, 2025
1965 - 1973 Classic Mustangs -General/Talk- Jan 23, 2025
LILCBRA
  • Poll Poll
Pull engine & trans together or just engine?
  • ShawnR
  • Jul 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 2, 2026
RaggedGT
O
Help
  • OnisimusD
  • Oct 13, 2025
1965 - 1973 Classic Mustangs -General/Talk- Oct 14, 2025
OnisimusD
O
