question about my heat
5.HO
14
NEW JERSEY
well when i got the car the heat seemed to be working fine. the guy said he put in a new heater core. now it doesnt work. its freezing out and every time i drive the car, i can see my breathe in the air! any way to see if i have a clogged heater core?
yeh pull off both heater hoses. The two small coolant hoses at the firewall and run a hose through it see if it flows freely. Fist thin I would do though is make sure the car has a thermostat in it, and is full of coolant. Thant could be your problem.
well i'm pretty sure it heats up... but my temp. gauge is not working. after like 5-10 minutes it goes all the way up like its over heating... then it sometimes goes randomly all the way back down... it shows NO signs of overheating.
i would think that if your heater core were clogged the hoses to the heater core would be leaking, since coolant flows through it all the time the pressure would build up and something would give. i recently changed my heater core the signs that it was going bad were foggy windows all the time, and heat that smelled horribly (besides the car overheated from loss of coolant) if it were the heater core youd know. there is a flap in your HVAC box that opens and closes when you turn your tempurature knob it opens via gear and wire attatched to that knob. the flap lets air pass through the section of the box with the heater core. maybe somethings disconnected and the air isnt passing through the box with the heater core and there is no hot air coming out the vents....:shrug: its just a guess but i think if something were wrong with coolant flow you would notice other problems
hmm interesting. i dont know to much about heat and AC. so if the heater core needed to be replaced, i would have heat in the car? when i turn it on, just air comes out of the vents. its NOT warm. do you have any pictures of what i need to look at? also, i would have a coolant leak if the heater core was bad?
if the heater core was bad you would be noticing symptoms like
-strong smell of antifreeze when vents/heat is on
-foggy windsheild that wont go away with defrost
-antifreeze leak inside the car (on passenger side floor) making for stainde carpets/floormats
-a leak from the firewall a/c relief drain (how i noticed mine) this will leak out onto street to under the car
if your heater core was bad youd smell antifreeze, the air probally wouldnt be very warm either, but if the car is holding all the antifreeze i would look elsewhere for a problem before i dig out the heater core, its a job and a hallf and you wouldnt want to do it for nothing.
i would see if the airflow is correct and the air isnt just bypassing the heater core (say if you were to have the vent on cold but no ac turned on) remove the HVAC controlls and just pop it out a little see if the gear is moving the rod which moves the flap sorry i dont have any pictures
I have a coolant funnel like this one
After draining coolant on something I put this on and fill till it stops taking it. Then start the car or truck up with the funnel still on the rad and let idle till it hit's operating temp and the T-stat should open and burp out a bunch of air and the level in the funnel will drop and then I plug the funnel and pull it off and install the rad cap. Sometimes I place a long screwdriver inbetween the seat and gas peddal to help speed up the heating up process by letting the car idle around 1500 RPM.
