- Sep 9, 2004
- 338
- 0
- 0
Ok guys, i've been chasing down a pinging problem for sometime now (who hasn't?) I've done what a lot of people recommended. My car basically bone stock down to the old air box I just put back on. I just replaced the ACT and ECT and while they helped my car still pings (not as much as it used to). So heres my theory. If i'm in 2nd or 3rd gear and I full throttle it, at times it doesn't ping. It mostly happens if i'm at a slow roll or stopped in 1st gear. My car is at 120k miles so I'm starting to suspect the timing chain has slack in it. If i'm pinging only in 1st gear when there is heavy load, it would make sense why I wouldn't ping in the other gears when I'm cruising and get on it (when there isn't that much load). And if the car is losing timing from the chain it would make sense that all the other sensors would have to be in tip top shape so even more timing wouldn't be lost from the thermisistors and stuff. Now besides taking the timing cover off the car and checking for slack phyically. Would I be correct in assuming that I can just take the spout out and check the timing at say 3k and 4k rpms and if it isn't the same as the 10* at idle then the timing chain most likely has slack in it?
Also while I'm here, why do a lot of guys replace the timing cover when they do their chains? Is it mandatory with an aftermarket chain for clearance? just for cosmetics? or because it is something that could potentially crack down the road?
Thanks guys!
Thanks guys!
