  • SN95 4.6L Mustang Tech
Question about PI cams
  • Thread starter Thread starter Texstang9682
  • Start date Start date May 15, 2007
Texstang9682
115
Austin, Texas
May 15, 2007
  • May 15, 2007
Ok so I found an excellent deal on some used PI cams online. They only include the cams though. They dont have the gear or sproket for the timing chain. Is this a big deal? Can I use my cam gears? By the way my car is a 96 and they will be going on NPI heads.
What do yall think?
COramprat
...I can take it. I think.
20+ Year Stangneter
Mar 2, 2003
8,474
1,463
223
Sea of Tranquility
May 15, 2007
  • May 15, 2007
As long as you have bolt on gears you will be fine.
LI98GTStang
1,715
L.I., NY
May 15, 2007
  • May 15, 2007
your 96 will have the bolt-on cam gears that you can move over, but will need new bolts to hold them in as the NPI is a different size from the PI bolts.
RandyStinchcomb
1,159
Randallstown, Md
May 15, 2007
  • May 15, 2007
as long as the cams have a threaded end, your fine but make sure they ARE Romeo PI cams and not Windsors wth the gears removed. if you can get stamping #'s off of them, I can de-code.
now if they are Romeos, as stated above you can re-use your gears, washers and spacers but you will need 2 new 10mm cam sprocket bolts, part # YF7Z-6279-AA and sell for @$3.00 each
Texstang9682
115
Austin, Texas
May 15, 2007
  • May 15, 2007
Well I can't get the guy to answer my question. Should I just wait and get some other cams? What if they were windser cams would they still be usable? Also Randy If I was to get some parts from you how would I go about doing that?
Thanks, Clint
RandyStinchcomb
1,159
Randallstown, Md
May 16, 2007
  • May 16, 2007
Thanks, Clint
yes you can use Windsor PI cams on a Romeo head, no problem there.
now if you need to get ahold of me, hee is my # 410-655-2000 ext 5618
if you can wait for Romeo PI cams, then thats what I would do.
LI98GTStang
1,715
L.I., NY
May 16, 2007
  • May 16, 2007
So to clarify, the Windsor has the press-on style cam gears where as the Romeo has the threaded or bolt-on style? I had purchased mine through a Ford dealer in 2002 (they are '02 cams) and they are the bolt-on style. Makes it easier to install, that's all. Most press-on type stil have the cam gears on them so if they don't, the press-on type would need the cam gears put on, which would be trouble in a home garage (at least mine).
RandyStinchcomb
1,159
Randallstown, Md
May 16, 2007
  • May 16, 2007
LI98GTStang said:
So to clarify, the Windsor has the press-on style cam gears where as the Romeo has the threaded or bolt-on style.
that is correct
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
  • Mindseye007
  • Aug 16, 2026
Mindseye007
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
