question about trick flow top end kit
  • Thread starter Thread starter nibik91
  • Start date Start date Aug 10, 2010
N
nibik91
51
  • Aug 10, 2010
this has probably been asked a million times before, but is the trickflow top end kit the best rout to go for a daily driver street car? or part it together with the usual gt40 heads upper and lower, cam ect... is it truly a bang for the buck deal?
russ1979
152
albuquerque, new mexico
Aug 10, 2010
  • Aug 10, 2010
:bump::bump::bump::bump::bump:
this could be good info
CDQICKGT
229
fort hood, tx
Aug 10, 2010
  • Aug 10, 2010
I went through this the other day with a thread I started. As far as I've seen( few buddies have and are still running it). I was gonna do my own combo but other smacked me around and got me straight. My car is also a daily driver, and so are my buddies. There cars are alot more fun to drive than my b cammed gt40 combo. Overall they run smoother and seem to be a little more reliable. Only reason I was looking away from the package deal was I wanted something different. But for the sake of simplicity and time/effort/headaches I will also be doing the TFS thing... Stock short block till next year. Then a 331 and a little more cam than the stage 1
90lxcoupe
20+ Year Stangneter
Oct 7, 2003
3,596
350
134
Aug 10, 2010
  • Aug 10, 2010
it would be a good setup for a daily driver but if you shop around you could probly put together a better combo for a little less money
Cobra912
1,777
11
39
Wish I was anywhere but here
Aug 10, 2010
  • Aug 10, 2010
depends on how much effort you wanna put into it. Buy it and know it will work, or spend a bit of time and research another combo that might be a better depending on your plans for the car
Rick 91GT
Mustang Master
95
99
PA
Aug 10, 2010
  • Aug 10, 2010
It is hard to put all those parts together cheaper, the kit is a good deal and perfect for a stock or 327/347 stroker shortblock. If I use the kit on a stroker I usually swap for the Track Heat intake and stage II cam.
russ1979
152
Aug 10, 2010
  • Aug 10, 2010
i would think that this kit would be to small for a 331 or 347.
maybe not tho
Gregg@TFS
Premium Sponsor
Feb 11, 2008
53
  • Aug 10, 2010
We did the homework for you and all the parts are in the kit. They make great daily drivers. If you have any question let me know.
Gregg
Trick Flow Tech
ReefBlueHatch
682
96
39
Central KY
Aug 10, 2010
  • Aug 10, 2010
I've been thinking about a TFS top end kit recently. But I still need over $1200 in supporting mods. I think I'd like to pull the the motor and the front clip, then have someone paint the engine bay while I put the motor back together.
Is the Stage 1 cam mild as far as driveability?
What's better - the Street or Track Heat?
What injector size would be good?
Gregg@TFS
Premium Sponsor
Feb 11, 2008
53
#10
  • Aug 10, 2010
  • #10
The stage I cam has very good street manners. I would recommend the Track Heat intake and 24lb injectors.
xherdlr
159
Hendersonville,Nc
Aug 10, 2010
#11
  • Aug 10, 2010
  • #11
I had the TF top end on my daily driver 89 vert. The car ran flawlessly on the street. Car ran high 12's at Bristol Dragway. I put 40k on the kit and because of recent economy,I sold my heads and intake. I just rebuilt the short block and now looking for some good iron heads to add to a ported stock intake and add a On3 turbo. The TFS kit is excellent value and top quality parts.
RARE NOTCH
73
Ohio
Aug 10, 2010
#12
  • Aug 10, 2010
  • #12
I have the top end kit minus the intake with ste stage 1 cam and i found a NOS GT-40 Tube intake cause i wanted to make the car look like it did back in the day. i know i gave up a little hp but it made 291rwhp and 324rwtq.
And it has awesome street manners and a blast to drive. And it has a nice lobe to the idle to.
russ1979
152
Aug 11, 2010
#13
  • Aug 11, 2010
  • #13
will the kit pass a sniffer test. with smog pump and cats on the car.
here in new mexico we need the test. it's not as hard as in cali but still a pain.
i could just pay off the tech by slipping him a 50 but it would be easer if it passes on it's own
Rick 91GT
Mustang Master
95
99
PA
Aug 11, 2010
#14
  • Aug 11, 2010
  • #14
maybe not tho
I had a customer make 340RWHP with that kit (trackheat intake, stage II cam) with only 8.5:1 compression. It makes good power and while I like some other combos better the kit is hard to beat if your on a budget....it definitly works.
xherdlr
159
Hendersonville,Nc
Aug 11, 2010
#15
  • Aug 11, 2010
  • #15
If all your smog equipment is present and operational,the kit will pass sniffer.
A
Discussion on mild budget build/ top end
  • Acesario
  • Feb 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 23, 2026
General karthief
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
SN95 Desktop 363 Engine Combination - Looking for input
  • WhiteCobra95
  • Sep 8, 2025
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2025
Habu135
Top End Kit or Supercharger?
  • 93gtmustang
  • Feb 24, 2024
  • 2 3
8K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 2, 2024
Bullitt347
J
Fox body - godzilla, coyote, or 408w stroker - Best route for budget build?
  • jaygee15
  • Jan 27, 2025
4K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 30, 2025
2000xp8
