Question bout deleting stuff A/C P/S ect.
The Shape
2,224
East ARKANSAS Delta
For those of you who have deleted A/C and P/S what bracket did you use? I want to stick with the stock rotation water pump if possible. Also other than a massive forearm workout what will happen if you just remove the P/S from the stock P/S rack? Will it explode, fall apart? I intend to eventually get the flaming river kit, but wondering if I can just cap off the rack for the time being?
when I bought my 90 mustang, it already had the smog pump & AC deleted. The guy said he bought the brackets/pulley kiits from summit. I deleted my power steering because the pump went bad. Didn't bother to cap off lines. I just jacked the car up and turned the wheels left & right until I got most of the fluid out. Then I cleaned up my engine compartment from the blown pump. Its a workout when you are in a parking lot for example but, at high way speed, Its no big deal to me. My water pump rotation didnt change. I use an 850K6 duralst belt. I have 215 70 r 15's on all 4 right now. I'm doing a 5 lug conversion in a couple weeks from now. I plan to do the old school, skinny in front wide in the rear but, not because I think its to hard to steer. Good luck with yours. Not sure what year car you have but hope this helps ya. I'm no expert, this is my first project build.
