Question 'bout MAF and TB, Fox and SN95 compatibility
MG-70
10
MD
Will a MAF or flow tube such as a C&L that's used on a Fox body car work on an SN95? I was under the impression one connects his/her electronics to the tube and (wire) pickups in the tube itself, and that the tube was pretty low tech.
Also, is the only difference in the '94/'95-specific throttle bodies the fact that they already come with an elbow connector or is there something else to it?
Thanks for your feedback
not sure about the MAF, but the TB is different. Fox and SN95 have different throttle body linkage and TPS setups. You will have to get a 94-95 if you want to keep your stock linkage. And no, the elbow does not come with.
