  • 1994 - 1995 Specific Tech
Question For VORTECH Guys!
  • Thread starter Thread starter 94GTLaserRC
  • Start date Start date May 15, 2004
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
May 15, 2004
  • May 15, 2004
Some of you have seen my posts here about some slight oil driping from near the connector of the drain line and fitting. Im pretty sure it's not the fitting connection at the pan. The hose is a little wet near the clamp, but I dont think it's running down the hose from up top, becaust higher up on the hose it is drier.
My main thought is a slight cut in the hose near the bottom, but with that mushy material surrounding the hose, it's hard to see a cut.
I was considering just getting a regular hose from Pep Boys and replacing it, but before I go through the trouble of removing the head and going through all that work, here is my main question:
Do you think I could just cut the hose about 12" up from the bottom fitting, insert a connector, clamp the upper "clothy" part of the hose and the newer lower part of the hose to the connector, and observe from that point to see if it still leaks.?
THis way, I can "check it out" by only doing about 20 minutes worth of work with the car jacked up.!
What do you think?
RC
94TURBO5 O
2,509
VA
May 15, 2004
  • May 15, 2004
Sounds like a good idea and I can't see any problem with that.
94GTLaserRC
11,178
May 15, 2004
  • May 15, 2004
Thanks JR, and did you get my post in your thread about the water heater hose?
RC
4Jenna
4,326
AZ
May 16, 2004
  • May 16, 2004
RC
You shouldn't have any probs with that...theres not much pressure on that drain line.
Good Luck
Chris
94TURBO5 O
2,509
VA
May 16, 2004
  • May 16, 2004
RC
Yup sure did Thanks!
94GTLaserRC
11,178
May 16, 2004
  • May 16, 2004
Where are all the other Vortech owners?
BTW...What exactly is the size of that drain hose...Im gonna get a piece today or tomorrow, and I dont have time to crawl up under the car.
Thanks
RC
94TURBO5 O
2,509
VA
May 16, 2004
  • May 16, 2004
I just measured the drain nipple and it is 1/2" across. I measured the hose and it is 18" in length with a 2 1/2" circumference and 1/2" in diameter.
4Jenna
4,326
AZ
May 16, 2004
  • May 16, 2004
Get some nice steel braided line, with some purty red fittings to match your car!
94GTLaserRC
11,178
May 16, 2004
  • May 16, 2004
Normally I would do that Chris, but you cant even see that hose!
Besides, for now, Im just gonna connec the spice in the middle and continue to observe for leaking. If it continues, THEN Ill take off the head and redo the whole thing.
Where is the best place to get the S.B line in 1/2" that youre referring to?
RC
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
M
2001 evap/heater core questions
  • mnky99
  • Sep 3, 2025
SN95 V6 Mustang Tech Sep 3, 2025
mnky99
M
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
M
  • mnky99
  • Sep 5, 2025
mnky99
M
