question for you five-o'ers
  • Thread starter Thread starter 68stangman
  • Start date Start date Feb 26, 2006
68stangman
49
New Orleans area
Feb 26, 2006
  • Feb 26, 2006
I've got an 89 longblock that I will rebuild an drop in my classic. Was the entire bottom end forged or just the pistons. Cause if it is just the pistons, those will be gone anyway in the rebuild. Need to start formulating my plan so I can make it happen this year.
troyGT03
278
too close to memphis,tn
Feb 26, 2006
  • Feb 26, 2006
yours will have forged pistons,cast crank,forged rods.
68stangman
49
New Orleans area
Feb 26, 2006
  • Feb 26, 2006
thank you sir!
FastDriver
I was uncomfortably high & wearing a helmet
SN Certified Technician
Sep 5, 2001
6,239
2,945
224
Vass, NC
Feb 26, 2006
  • Feb 26, 2006
If the rods are forged, it doesn't matter. They are the weakest link. Get some aftermarket rods...
ninety15.0
1,336
  • Feb 27, 2006
I dont know if that is correct fellas. Im pretty sure the rods are cast and i know the pistons are forged but im not sure on the crank....the rods are not really the week link....the block is. The block will only withstand about 450rwhp, any more than that or too many rips up to the real high revs and you'll split that bad motorscooter right down the middle. The rods are also good to about 450rwhp. Consider the costs of a fully forged bottom end and then think of how much power u wanna make....and if its around 500 horse, i wouldnt spend too much cash on the bottom end cuz it aint gonna last too long.
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Feb 27, 2006
  • Feb 27, 2006
No, they are not; the block is.
Troy was right; cast nodular iron crank, forged steel rods, and forged pistons.
68stangman
49
New Orleans area
Feb 27, 2006
  • Feb 27, 2006
If the rods are forged, I should not have to replace them, right? I figure if I need to replace the crank and rods, I might as well go 331. But if the stock crank is good and the rods are forged, why replace them. I would be perfectly fine with a 306 that will give me a thrill. My stock engine new was only rated at 190 bhp. 300 to the rear wheels - man, I can go for that.
.010 on the crank then balance the rotating assembly, right?
but if the rods were not forged, I would probably want to upgrade
Realmongo
I prefer to be called "Evil Genius"
2,466
86
99
Western Mass
Feb 27, 2006
  • Feb 27, 2006
Is the engine an original Mustang 5.0? If it is out of a passenger car the pistons won't be forged.
sirr0bin
174
Winnipeg, Manitoba
Feb 27, 2006
  • Feb 27, 2006
I know for sure the 87-92 302's had forged pistons, and the 93's had hypereuetic (sp?)
Sicarius428
2,085
Feb 27, 2006
#10
  • Feb 27, 2006
  • #10
If you are using the stock block, don't bother replacing the crank with a foraged unit. The block will almost always break before the crank does... 331 stroker in a classic would be awesome.
Kevin
65ShelbyClone
4,675
38
119
Feb 27, 2006
#11
  • Feb 27, 2006
  • #11
Sometime around mid '92 was the switch to hyperutectic pistons. The not-so-reliable rule of thumb is if your engine came factory with a gray oil pan, it has forged pistons. If it came with a black pan, they are hypers. Its not reliable because the plant that built the engine might have had more gray pans than forged piston engines and put the spares on hyper engines.
I forgot to mention that this only applies to 5.0 HOs(Lincoln Mark VII LSCs, Mustangs). The rods are only a weak point if you start approaching 7000rpm. By then the block is questionable anyway. You should have 180,000psi+ bolts no matter what.
Engine Looking for suggestions and or ideas
  • PonyGTrider
  • Aug 25, 2026
PonyGTrider
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
9
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
  • brandyn200
  • Jun 20, 2026
AeroCoupe
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
