question for you five-o'ers
I've got an 89 longblock that I will rebuild an drop in my classic. Was the entire bottom end forged or just the pistons. Cause if it is just the pistons, those will be gone anyway in the rebuild. Need to start formulating my plan so I can make it happen this year. :nice:
I dont know if that is correct fellas. Im pretty sure the rods are cast and i know the pistons are forged but im not sure on the crank....the rods are not really the week link....the block is. The block will only withstand about 450rwhp, any more than that or too many rips up to the real high revs and you'll split that bad motorscooter right down the middle. The rods are also good to about 450rwhp. Consider the costs of a fully forged bottom end and then think of how much power u wanna make....and if its around 500 horse, i wouldnt spend too much cash on the bottom end cuz it aint gonna last too long.
If the rods are forged, I should not have to replace them, right? I figure if I need to replace the crank and rods, I might as well go 331. But if the stock crank is good and the rods are forged, why replace them. I would be perfectly fine with a 306 that will give me a thrill. My stock engine new was only rated at 190 bhp. 300 to the rear wheels - man, I can go for that.
.010 on the crank then balance the rotating assembly, right?
but if the rods were not forged, I would probably want to upgrade
If you are using the stock block, don't bother replacing the crank with a foraged unit. The block will almost always break before the crank does... 331 stroker in a classic would be awesome.
Kevin
sirr0bin said:
I know for sure the 87-92 302's had forged pistons, and the 93's had hypereuetic (sp?)
Sometime around mid '92 was the switch to hyperutectic pistons. The not-so-reliable rule of thumb is if your engine came factory with a gray oil pan, it has forged pistons. If it came with a black pan, they are hypers. Its not reliable because the plant that built the engine might have had more gray pans than forged piston engines and put the spares on hyper engines.
I forgot to mention that this only applies to 5.0 HOs(Lincoln Mark VII LSCs, Mustangs). The rods are only a weak point if you start approaching 7000rpm. By then the block is questionable anyway. You should have 180,000psi+ bolts no matter what.
