  • SN95 4.6L Mustang Tech
Question on brake installation/result
  • Thread starter Thread starter mustang4lyfe
  • Start date Start date Jun 12, 2011
M
mustang4lyfe
24
  • Jun 12, 2011
I drive a 2000 Mustang GT, and i recently ordered new pads and rotors off ebay, I had a few people recommend them so I gave em a shot since they were kinda lower cost but still nice. Today i put the rear rotors and pads on and the fitment is pretty snug mabey almost to much? I have everything together correctly I believe and even with the tire on i can turn it at all by hand. Is this just how it is when you install brand new pads since there pretty thick or was i supposed to sand them down somewhat? I could really use some help. Or after I drive around for a bit will the pads break in and loosen up a bit? the rotors are drilled and slotted and they are evolution ceramic pads.
Thanks
bigkeeko
63
Scotland
Jun 12, 2011
  • Jun 12, 2011
Relax. Its good. Normal stuff.
M
mustang4lyfe
24
  • Jun 12, 2011
Are u sure that its normal? I mean I cant even turn the wheel at all with the tire on and snugged.
Maxpowers
859
Pittsburgh, Pa
Jun 12, 2011
  • Jun 12, 2011
You should never sand any part of your brakes.
This is normal. Did you follow the break in procedure? If not, they will be shaking in a few hundred miles.
M
mustang4lyfe
24
  • Jun 13, 2011
I havn't even drove with them yet, I just recently installed the rear rotors and pads and still have the car on stands to finish with the front rotors and pads now but I do have a slip of paper that says for break in I should do 5 hard stops from 40-5 without letting brakes cool then 5 moderate stops 25-5 while letting brakes cool in between each braking session. Does that sound some what right because i didn't know if that was to be done with new rotors, I'm kind of new to this because it's my first brake job. But yeah so far I only did the rear brakes and I can't turn the tire by hand so I was just curious if it was supposed to be that tight and if it would wear down some what after a bit of driving, which you guys seem to think? Correct?
Maxpowers
859
Pittsburgh, Pa
Jun 13, 2011
  • Jun 13, 2011
Sounds like you may need to screw in the caliper a little more. It will wear down some, but not right away. This will ruin your break in procedure.
The break in sounds correct to me.
M
mustang4lyfe
24
  • Jun 13, 2011
Well the thing is I used the caliper tool to push the piston back in and I think i have it in all the way because it is flush with the rubber housing around the piston if not a little further by about a cm or so. Also to do the break in steps I have to drive a little ways to get to a safe and sufficient spot to break them in will it be "ok" if I just apply the brakes very lightly and drive much slower than usual?
Maxpowers
859
Pittsburgh, Pa
Jun 13, 2011
  • Jun 13, 2011
I down shifted and didn't hit my brakes until I was breaking them in. A little won't hurt, but do not heat them up.
M
mustang4lyfe
24
  • Jun 14, 2011
ok sounds good thanks!
Brakes Rear brakes feel stuck after replacing pads and rotors
  • 99stanggtvinx
  • Aug 31, 2024
SN95 4.6L Mustang Tech Sep 1, 2024
nickyb
J
2003 convertible front brakes sticking
  • jamesbanasky
  • Jul 9, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 6, 2025
jamesbanasky
J
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
M
  • Locked
2001 evap core tube support
  • mnky99
  • Sep 4, 2025
SN95 V6 Mustang Tech Sep 5, 2025
mnky99
M
water pump installation questions
  • B0udreaux
  • Feb 5, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 28, 2026
General karthief
