Question on code 94
89_FakeSnake
93
Sacramento, CA
Symptoms: Choppy idle and major loss of power above 2500 RPMS.
I'm starting off by making sure all vacuum lines/components look correct - and this one solenoid raises question. This is located on the rear of the passanger shock tower closest to the motor. I've been noticing an increasing underhood whistle forming (louder than the normal whistle coming from my throttle body) and was wondering if this could be the reason??? I'm not sure if the crack continues all the way underneath so I really can't tell if it's all the way through the housing.
When I say it's got a loss of power....I mean it's like hitting a wall in the RPM's above 2500. All smog equipment still hooked up and running stock h-pipe. Mods are basic bolt-ons - Cobra Intake, E303 cam, GT-40P heads.
Any input is GREATLY appreciated!!!
A vacuum leak and poor idle due to the cracked part is possible. The power loss is likely something else.
Here's the code 44/94 test path.
Codes 94 & 44 - AIR system inoperative - Air Injection. Check vacuum lines for leaks, & cracks. Disconnect the big hose from smog pump: with the engine running you should feel air output. Reconnect the smog pump hose & apply vacuum to the first vacuum controlled valve: Its purpose is to either dump the pump's output to the atmosphere or pass it to the next valve. The next vacuum controlled valve directs the air to either the cylinder heads when the engine is cold or to the catalytic converter when the engine is warm. Disconnect the big hoses from the back side of the vacuum controlled valve and start the engine. Apply vacuum to the valve and see if the airflow changes from one hose to the next.
The two electrical controlled vacuum valves mounted on the rear of the passenger side wheelwell turn the vacuum on & off under computer control. Check to see that both valves have +12 volts on the red wire. Then ground the white/red wire and the first solenoid should open and pass vacuum. Do the same thing to the light green/black wire on the second solenoid and it should open and pass vacuum.
Remember that the computer does not source power for any actuator or relay, but provides the ground necessary to complete the circuit. That means one side of the circuit will always be hot, and the other side will go to ground or below 1 volt as the computer switches on that circuit.
The computer provides the ground to complete the circuit to power the solenoid valve that turns the vacuum on or off. The computer is located under the passenger side kick panel. Remove the kick panel & the cover over the computer wiring connector pins. Check Pin 38 Solenoid valve #1 that provides vacuum to the first Thermactor control valve for a switch from 12-14 volts to 1 volt or less. Do the same with pin 32 solenoid valve #2 that provides vacuum to the second Thermactor control valve. Starting the engine with the computer jumpered to self test mode will cause all the actuators to toggle on and off. If after doing this and you see no switching of the voltage on and off, you can start testing the wiring for shorts to ground and broken wiring. An Ohm check to ground with the computer connector disconnected & the solenoid valves disconnected should show open circuit between the pin 32 and ground and again on pin 38 and ground. In like manner, there should be less than 1 ohm between pin 32 and solenoid valve #2 and pin 38 & Solenoid valve #1.
If after checking the resistance of the wiring & you are sure that there are no wiring faults, start looking at the solenoid valves. If you disconnect them, you can jumper power & ground to them to verify operation. Power & ground supplied should turn on the vacuum flow, remove either one and the vacuum should stop flowing.
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host)
http://www.veryuseful.com/mustang/tech/engine/images/88-91eecPinout.gif
See http://forums.stangnet.com/showthread.php?t=702472 for a very nice drawing of the Thermactor Air System (smog pump) plumbing.
If you have a catalytic converter H pipe, you need to fix these codes. If you don't, then don't worry about them
