I have one of those engines in my Twister II for now. Some things to consider are 1) It's a brand new engine with everything from the oil pan to the heads already included. 2) You will need to supply your own: Intake, Fuel Delivery System, and Ignition regardless of your application 3) If you put it in a Fox body, you'll need to replace the water pump and oil pan with a Fox-compatible set (your original stuff will bolt right up) 4) If you go carbureted, you'll need to swap out the timing cover (and add the eccentric to your cam) if you use a mechanical pump 5) If your belt system is not compatible with the crate engine's, you'll also need to swap out the harmonic damper to provide for clearance, etc.
I'm quite happy with the performance, and I'm certain durability is going to be good (right now at about 6,000 miles) since it was built and test-run at the Ford factory. The only drawbacks are 1) the time / effort / cost associated with making the engine work in a Fox body 2) The relatively dated technology associated with the GT40 heads and the B-cam 3) Not a forged bottom end 4) Relatively high compression and cam profile necessitates high octane fuel in my application.
On the good side, it really does run strongly, and sounds great. It pulls a solid 300 rwhp with my Edelbrock Performer RPM Intake, Crate Demon 650 carb, Crane Street / Strip Distributor and HI-6 Ignition. It's also worth considering that I get over 20 MPG in and around Washington, DC, and that's nothing to sneeze at, either.
If you're willing to do a little part-swapping on your own, it's hard to beat for the money. For about twice as much, you can have a sweet stroked, forged engine with intake and ignition. It's just a matter of cash and desire.
Good luck!
