I'm completely redoing my suspension either this weekend or the next and figure while I have all the stuff removed I might as well address the surface rust I see on the inner fenders. From what I can tell it doesn't need anything more than a wire wheeling/sanding to get rid of all the surface rust and then some coating/paint.
I've been doing a bit of research as to what products/process I could use. I'm thinking about
-Wire wheeling/sanding down
-Cleaning really well (thoughts on what cleaner I should use?)
-Use Eastwood's Rust Converter (this is basically a phosphoric acid that leaves a rust inhibiting residue behind right?)
-Finish with Eastwood's brush on Rust Encapsulator in black.
How does that sound?
How much Converter and Encapsulator would I need? Quart each?
Also I was looking at the FAQ section on the converter product page and saw this:
"Application - It is important to apply a thin coat first and allow it to dry before applying a second coat. Allow the surfaced to cure for 48 hours and protect it from moisture, rain, or dew"
Does that mean prior to applying the converter clean the surface and let sit for 48 hours? Or after applying the converter allow it to cure for 48 hours before applying say the encapsulator? I would think the latter, but its not all that clear to me. I'd like to be able to do this in a weekend and I don't have a garage so using this kind of sounds like a pain.
All other suggestions welcome! I'm a bit new to this.
