Questions Mark 8 swapp
  • Thread starter Thread starter RuffGT99
  • Start date Start date Oct 19, 2019
R
RuffGT99
Nor Cal
Oct 19, 2019
  • Oct 19, 2019
Hey guys, I have a few stangs. I have a 96 mark 8 i was considering swapping the engine to my 99. Should I swap the intake and heads? or Just rebuild it and the whole dang thing?
General karthief
Mod Dude
Aug 25, 2016
27,988
10,616
213
polk county florida
Oct 19, 2019
  • Oct 19, 2019
I think the mark vlll was an aluminum block/heads like the cobra engine, sounds like a good swap to me. I think there was some swap issues with some cranks not drilled for a pilot bearing but I'm no modular melvin so I'll move this to a forum with some more experienced members.
tsemmett
276
33
38
US
Oct 23, 2019
  • Oct 23, 2019
Some things to consider:
  • The 4V heads have a larger combustion chamber (51cc vs 42cc), enough to drop your compression ratio by about a point (roughly 8.2:1 on your 2V shortblock).
  • These are 4V B heads, which the general consensus is that they require boost to be worth much.
  • The Mark VIII engine has runner controls that the Mustang doesn't (have to be deleted).
  • Stock for stock, there's about a 20hp difference between the two engines.
The good news is that this would be an all aluminum engine, with a Teksid block. If you have the desire to build something a bit meaner, it's a good starting point (though I find a set of C heads and an intake to match personally).
J
1996 v6-v8 swap
  • jujuonurmom
  • Oct 28, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 28, 2025
jujuonurmom
J
97 GT with 03 explorer Eddie Bauer edition 4.6l
  • basbill73
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 11, 2026
squeak93
E
Chasing Vacuum leak 99 GT
  • EBNS_2005
  • May 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 3, 2026
X-cam34
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
E
4.6l auto to 5.4l 6 speed
  • EastanF5
  • Jan 22, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jan 22, 2026
EastanF5
E
