OK what causes a clutch to chatter only when its hot, if I dive it when its cold it is smooth. After it warms up its noticeable. Also if I'm cruising, for example in 2nd gear, and the rpms are at about 2000 and i let off the throttle on deceleration it will buck, also if I'm cruising and i kinda tap the gas real quick to get the car to jump forward it bucks also. There seems like there is a lot of slop in the drive train, when i shift into second i get a thud and a lot of drive train movement? rear end, drive shaft, u joints, trans or motor mounts?? could it be any of them???
In the old days we'd find an empty stretch of road (I mean a closed road course) and light 'em up................... There's always a chance this will make it worse (we were prepared to replace the clutch anyhow).
