Quick Cluster Question
  • Thread starter Thread starter Mafia Mustang
  • Start date Start date Jun 10, 2008
M
Mafia Mustang
111
Arizona
Jun 10, 2008
  • Jun 10, 2008
Quick question guys/girls.
Say My Insterment Cluster Was Misplaced and I bought another one From My
Year or close to it. if I plug everything in to the new Cluster will it Automaticly be
right with my car like the gas gaudge for Example. or is there some ajustment
needed to get it insync with my car?
btsclan
64
Seattle, WA
Jun 10, 2008
  • Jun 10, 2008
What year is your car and what year is the cluster you are putting in.
The only difference I know of is on 89-93 models that were equiped with airbags, there might be a fit issue since the bottom side of the cluster unit is different then the 87-88 models. As far as the electronics, I am pretty sure that it should be a straight swap, but I am not 100% sure,
For instance I have a tach and a speedo from an 89 stang on my 87 and it works just fine, but in that case all I did was replace the actual tach unit and the speedo within the cluster itself.
Good luck
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Jun 10, 2008
  • Jun 10, 2008
What year is your car?
M
Mafia Mustang
111
Arizona
Jun 11, 2008
  • Jun 11, 2008
Its a 1990 Pretty much what im asking is if i plug in a new cluster will it read everyting correlty like the gas and temp or will I need to ajust it some how? same year same cluster.
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Jun 11, 2008
  • Jun 11, 2008
You can put a 1990-1993 cluster.
Plug it in and everything will work
Adjusting the miles to read correctly will require disassembly though...unless you have a drill and a lot of free time
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
P
Progress Thread New To Me 1988 GT - trying to set up vacuum lines for upper intake question
  • pindude80
  • May 6, 2025
  • 9 10 11
16K
Fox 5.0 Mustang Tech Mar 28, 2026
pindude80
P
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
Electrical Oil Pressure Gauge IN Dash Cluster Unresponsive
  • Nine Finger Wrenching
  • Jan 7, 2025
Fox 5.0 Mustang Tech Jan 8, 2025
85GTStangGuy
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
