quick power windows question
  • Thread starter Thread starter Copperstang87
  • Start date Start date May 18, 2005
C
Copperstang87
163
Thunder Bay, Ont
May 18, 2005
  • May 18, 2005
I've read other threads and got alot of diff things of wut could b wrong in my car but I wanna know if someone knows exactly wut this problem is.
Basically my drivers side window goes up and down no problem and my passenger side window does not go up or down. The drivers side switch(master switch) doesnt work for passenger side and passenger side switch does not work for passenger switch either, can anyone help me out plz?
Any help would be greatly appreciated.
super302
I'd do anything for free Bapples
May 29, 2004
2,878
Davenport, IA
May 18, 2005
  • May 18, 2005
most likely the motor is shot....there is these three pieces you can replace (really cheap) in the motor, they are white cylinderical objects (if this doesn't work, there is a great possibility it is your actual motor)
C
Copperstang87
163
Thunder Bay, Ont
May 18, 2005
  • May 18, 2005
ok thanks, where abouts is all this stuff? im assuming I hafta take off my drivers side door panel?
billpo
45
Ottawa, Ontario
May 18, 2005
  • May 18, 2005
Yes you will have to take of the panel . For easy access to the motor
remove your speaker. there is a plug there that attaches to your motor. You
will have to unplug this. There are 3 screws that attach your motor to the door. remove them, and remove the motor.
Bill
T
tjm73
2,418
Rush, NY
May 18, 2005
  • May 18, 2005
My car does a similar thing from time to time, but not with any regularity. But it does a little different. The drivers side switch won't put the passenger side window up/down, but the passenger side switch will. The passenger switch always works, so I suspect my problem is the driver side window switch it's self.
PuterAmI
513
Madison, Alabama
May 18, 2005
  • May 18, 2005
First, if *either* switch is bad on the passenger side, it will keep the motor from working. You need to verify that it is not a switch. Use your good one (driver's) and first place it in the driver's passenger switch and try. Then swap it over to the passenger door and try. You may also want to borrow a friend's known good so that you are testing with two known good switches in case both of them on the circuit is bad.
C
Copperstang87
163
Thunder Bay, Ont
May 18, 2005
  • May 18, 2005
okay so if my drivers side switch and passengers side switch wont make the passenger side window go up or down then its my motor? wouldnt it prolly b my drivers side switch(master) but it does work fine for the drivers side window, is it my master switch or my motor???
PuterAmI
513
Madison, Alabama
May 18, 2005
  • May 18, 2005
As tjm73 mentions, I had the same thing happen, only intermittently. The driver's switch of the passenger circuit would all of a sudden not work. I would use the passenger side switch and the motor would run. This went on for many months until the driver's side passenger motor switch eventually died and the window would not move no matter which switch I tried. I had to keep swapping the driver's side driver motor switch to the other circuit if I wanted the passenger window to move. Even cleaning the switches with Electronic Parts Cleaner spray did no good. Now I have a used good switch and all is fine. The window even moves up and down faster.
J
JB66
565
New York
May 18, 2005
  • May 18, 2005
Check this out before you do anything else.
http://forums.stangnet.com/showthread.php?t=546055
NosPony
278
Canton, Il
May 19, 2005
#10
  • May 19, 2005
  • #10
sounds to me like a bad motor easy fix 3 bolts hold it in.
T
Electrical Brown Connector #31
  • ta66
  • Jul 26, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
ta66
T
T
Fox Convertible top issues
  • TDM389
  • Feb 15, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 15, 2026
General karthief
Problems after exhaust install and 02 harness
  • djj62478
  • Jul 2, 2026
AeroCoupe
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
T
2002 V6 3.8L Help Me
  • TheIncompetentMechanic
  • Apr 4, 2026
  • 2 3
1996 - 2004 SN95 Mustang -General/Talk- May 12, 2026
T
