Yes and no. If you decided to do cams and valves then the cost is doubled but everything else is the same. CAI, headers, h/x pipe, cat backs, injectors, sensors, pumps, cooling system and all that is the same price wise. Well the CAIs are about $20-$40 more cause of the different bend but other then that.
To get good power from a 2V you have to port/replace the heads. With a 4V you dint cause they already flow more then enough to support well over 750 rwhp. Same thing with the plenums, don't need a P-51 or Trick Flow plenum for high flow rates. When you get to really high flow rates for over 600 hp you just remove the runners...... so it seems that if you have access to a cheap 4V that its cheaper to make power from it then the 2v
There are N/A 4.6 DOHC engines making 500 hp now with stock "C" heads. Is there any N/A 4.6 2V doing that yet? And I am not being sarcastic, I really don't know if there are 2V making that yet. Seems they were maxing at 440 ish.
So a used Mark engine should be around $400-$500 and with long tubes and free flowing exhaust and tune will do about 340 fly wheel hp. For a 2V to do that its gonna need heads or at least a plenum, both of which are more then $400, no? Plus he can sell off the 2V engine and offset the cost.
BTW, the "BS" Mark heads are excellent and flow more then "C" heads do. The "C" heads just have a higher velocity. The only real downside is nobody makes an intercooled plenum for a PD blower for them.
Also if you swap the heads you have to swap the plenum cause the ports are way different.
Lastly I have a Mark as well and with only a tune it really embarrasses allot of Stang and Charger drivers. The Stang is quicker to 30 cause of the weight and trans advantage but that 4V pulls hard past 3 grand and always walks right past them by 60.
