Quick question about my 5 lug swap
Front w/Cobra PBRs:
13" cobra rotors (2)
cobra PBR calipers (2)
cobra caliper brackets (2)
caliper pins (2)
spindle to caliper bracket bolts (4): N805163-S190
1994+ spindles (2)
Hubs (2)
hub nut(2)
dust cap(2)
dust shields (2) : F4ZZ-2K005A , F4ZZ-2K004A ($7.70 each)
SS brake lines designed for conversion - or - SN95 brake lines with Adapter
Balljoint spacer or stack of 3 washers totaling .330" in height or press in Sn95 balljoints to the stock arms (MOOG brand)
Banjo/caliper bolts (2) 10mm x 1.0 thread
Rear w/sn95 cobra disc (stock track for 79-93):
driver side Ranger axles or passenger side Aerostar axles (2)
11.65" vented cobra rear rotors (2)
sn95 calipers from 94-98 v6/gt/cobra (2)
soft brake lines (2)
pads for 94-98 cobra (1 set)
North RaceCar brackets (2)
FMS M2809A ebrake cables for 87-92 car (2) - or 93 Cobra cables for 1993 cars (2) F3ZZ-2A635-A
FMS M2810A center ebrake cable (1)
adapter from softline to hard lines (2)
I copied and pasted that off this ( http://mjbobbitt.home.comcast.net/~mjbobbitt/mustang/5lug.html ) website. Is that everything that I will need to switch to five lug? Also, for the parts for the rear it says to use 94-98 cobra rear calipers. Are they the same as the 10th anniversary cobra calipers I plan on using?
