Quick Question about wiring??
GREENBIOCH
1,241
In an Igloo
Well, I guess I figured I would post about this finally while its on my mind. I've been putting this off foir quite a while and really just want to know maybe what I can do to get rid of this sound which is more annoying than anything.
Anyways, when I have the stereo on and I'm driving as the rpms climb I get this high pitched noise going higher as the rpms keep going up, it is really noticable when stereo is turned up and more so when the radio is on then when it is the CD player. I Have an amp and one sub plus all of my speakers are pioneer. I also notice when I push power off on the factory deck it will give this loud buzz noise, now is it a grounding issue or is there a crossed wire or something else. I'm not good with electrical, so any info is appreciated.
Thanks in advance
Nathan
Like Saleen said, check your grounds, as that's what it usually is. If that doesn't help, you might make sure that your RCAs aren't running too close to the power wire, as that can also induce some noise sometimes. The bare metal thing is pretty essential for the grounding point. Sand off some paint if you have to.
Well I was kinda suspecting it, it is grounded to a bolt just behind the back flip down seat and there isn't much in the way of metal, like you guys said possibly coating on the metal, I will give that a try and see if works. Thanks again. :nice:
Sounds like a ground loop. This can be the result of several things. Poor ground, week or poor alternator dioads, other vehicle electronics. Have your amp power wire running to the amp on one side of the vehicle and your rca's running back to the amp on the other side. Find an isolated ground. Grounding the amp should be the only thing that this bolt, lockwasher and nut are for. Don't ground it to a seat bolt or near another piece of the vehicles electronics. ie. fuel pump, conv. motor. Best results are when the amp is grounded as close to itself as possible or 18 inches or less. If you have to drill a hole. Look before drilling of course.Go to your local car audio store or walmart and get a ground loop isolator. This goes between your head unit and the amp on the rca's. It will eliminate all or almost all alternator whine and noise. Their is also a noise filter that connects between your head unit's power and ground wires to the vehicles factory wiring. You just splice it inbetween the wires. These things will greatly help with or get rid of all your unwanted noise.
Thanks for all the tips! I'm gonna try regrounding my amp, once it warms up around here. It's like -30*Celcius and snowing like a mofo. If that doesn't help though I will try the ground loop isolator route. :D
gatzer sounds like he knows what he is talking about. :nice: But, before you try the filter route, I suggest you extend the ground from the head unit to the amp's ground. This will eliminate the ground loop between the head unit and amp. Try it, it's cheaper than a filter and only takes a couple of feet of wire.
