What is the easiest way to change my thermostat? from the looks of it i may have to take my water pump off just to get to the lower bolt..
I tried i cant get a socket in there..Jaswir said:you do not have to take your waterpump off to get to it... the bolts are right there you should be able to get to them easy.... i changed mine in like 30mins couple months ago!
May sound stupid but how do i mark it?Daggar said:You need a thin wrench, like the others said. not a socket wrench.
And yes... you will knock the timing off. Just mark it before you move it so you can put it back in the same spot.
RsStanG1987 said:May sound stupid but how do i mark it?
They look pretty rusted and both you and i know my history with rusted bolts and water passages.....ram360 said:try a marker...![]()
pull off the dist cap and mark the relation of the rotor w/ a mark on the inside of the dizzy before you pull it. No need to remove it though. I'd done them on both cars using a thin wrench.
RsStanG1987 said:They look pretty rusted and both you and i know my history with rusted bolts and water passages.....
If i dont fix it you may be towing me to PAram360 said:Leave it alone and I'll fix it for ya when you get to PA.
Its been 2 years exactly since i finished doing the motor on my blue stang...ram360 said:^ and that was just my 2000th quality post on stangnet....:SNSign:![]()
