I always did like the 2v engines myself. They are built pretty stout it seems. Look at the Lightnings..production 2v engine with lower comp. pistons. Rest is production hardware, If I remember correctly from the training course back in the day. The Terminator was the only one to receive all the Forged goodies.
I personally know a fellow bracket racer that has a high 11 sec. Lightning with almost 10k miles and 5+ years of bracket racing on the odometer since it was removed from street duty.
But I always did read that the 2v motors had weak rods/pistons, although i've never seen one break in that manner, but haven't been around a WHOLE lot of them that are pushing major HP either
I like the thread posted a ways up with the Turbocharged 2v engine, that's a good example of it can be done with the Ford stuff as well, and cost wise it's close. But, it always seems as if there is parts breakage, albeit an oil pump which is a known issue on those, at those HP levels. Whereas the production GM motor, with it's 6 bolt mains, Steel Crank and well documented cases of taking 800HP daily, seems like a better choice to me when $500 buys the entire motor with accessories/intake/pcm and wiring.
However......that new Shelby...is pretty impressive.
Ford's on the upswing guys, it's just taking them a bit to play catch up with the other manufacturers. At present time the hardware is still a bit expensive, but with those new 5.0's going into trucks and such, won't be too long and they will become an affordable powertrain as well.
On a side note, got to test out the car some.
6psi (15 capable!)
Moderate Pump Gas Timing
2.73's
TH400
2nd gear
1080P for those of you with Hi-Def!
Burnout test - YouTube
