  • SN95 4.6L Mustang Tech
Race Shifting
  • Thread starter Thread starter UndeadRogue
  • Start date Start date Jun 16, 2005
UndeadRogue
47
San Diego
Jun 16, 2005
  • Jun 16, 2005
Ok...so most of the time ive been afraid to let loose when at a stop light...normally I just give it enough power to beat the rice burners
So my questions are...
1. how should i be shifting in a street race at a stop light?
2. Whats a safe rpm to launch at and how fast should I let out the clutch...
3. how bad is power shifting?
4.how bad is it to be winding up to 5000rpm
Thanks
Jason
9646gt
595
Holloman AFB,NM
Jun 16, 2005
  • Jun 16, 2005
To know where the best shift point is you would really have to dyno the car if you have mods or anything to make sure you are shifting before the powerband drops iff..I shift around 5400 in my car bc any more than that and the car no longer feels like it is pulling..a launch would be good to start around 2k and see what works best..most of the time you will want to slip the clutch enough to get a quick take off without burning the tires off..Best thing to do is hit up a drag strip and you will learn alot about your car ..
UndeadRogue
47
San Diego
Jun 16, 2005
  • Jun 16, 2005
thank you...I lose my pull around the same area...but im afraid to get close to the red line unless I can really watch my tach...should I be worried about getting close or slightly crossing the redline
9646gt
595
Holloman AFB,NM
Jun 16, 2005
  • Jun 16, 2005
I dont think you should ever rev any harder than you have to..you should always shift where the power falls off..any mroe than that will slow you down and not to mention add more wear to the motor..as far as hurting the motor ..I dont suggest you constantly run over 5 grand as it creates alot of friction in the motor..thats why racing is hard on them
hotdog71
427
Seattle, Eastside
Jun 16, 2005
  • Jun 16, 2005
Mine pony has 29k on the clock and is running like a pony should sweet and I don't drive like miss daisy either.
It's seen many of hard driving times road and track. I always shift right around <100 rpm below the limiter when racing. The whole reason for shifting as high a possible in the rev range is to be in your power band for the next gear.
Change your oils and keep your fluid levels checked, drive the arse off the pony and if something beaks fix it as always.
my_03GT
186
DE
Jun 16, 2005
  • Jun 16, 2005
Be carefull in So Cal, street racing,I have been told they impound then crush your car, no questions asked if proven guilty. Just a heads up!
UndeadRogue
47
San Diego
Jun 16, 2005
  • Jun 16, 2005
yeah it suxs...if your lucky and dont get impounded the fine is twice as much as a DUI...heard of people getting nailed for 5-7k
But you have to be "racing" not just speeding...My neighbors a CHP...just say that you were driving this speed and so was he...
if you can pull off a story that his driving wasnt effecting your speed..u should be ok...also the ticket for 99 is in the low 300's and a ticket for 100 is 700
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
