radiator fluid mysteriously dissapearing...
deftsound
Please ask me how much my supercharger cost
Apr 6, 2004
945
Texas City TX
guys, ive noticed my radiator fluid has been dissaprearing at an alarming rate, it doesnt seem to leak, i dont see any visual leaks anywhere. Thinking it was my upper and lower intake gaskets i replaced those but it hasent helped any. It seems like every few hundered miles or so i have to refill my radiotor fluid back to spec. Its wierd, i have no idea where it is going...
is your passenger floor board wet at all? Do you smell anti-freeze? Your heater core could be leaking. Also check the firewall and see if you notice any coolant. Either that, you're burning it like giddyup suggested, or it's evaporating/boiling away. If your rad. cap doesn't seal properly, it lowers the boiling point causing the coolant to boil, thus evaporate, so you might try a new radiator cap if it's been a while since you're replaced it.
i would check out the heater core hoses. I had one leak, started smoking and smelling really sweet kinda. Opened it up and coolant was flying everywhere, the smoke burns your eyes too. I had just filled up the coolant and like 100 miles later it did that.
:bang: i hope my block isnt cracked, no i dont have a heater core and it never gets wet on passenger side, i kinda wanna think that im burning that fluid...i hope i am, i guess that would be better then my block being cracked, i just got a new water pump so i know thats not the issue, and i just got a new rad cap so thats not it either, where would it be burning it? And what can i do to fix this?
I found some small pinhole leaks at near the bottom of my rad (out of sight when looking from the top) last fall when I was doing some work on the engine. Got it recored although if I had to do it again, I'd just buy a new rad.
A couple more common problems are leaking heater hoses/tubes above the lower intake manifold and the EGR coolant lines and gaskets. The coolant can be dripping slowly onto the manifold, valve covers and/or headers and evaporating without leaving any puddles.
I have replaced all of that too and my heater core is bypassed.
umm if you dont have an overflow bottle that could be where its going....like just to outside, would take a while to get hot enough and u would only lose coolant when it got hot. you need to understand its a CYCLE, when your radiator fluid gets hot it goes into the overflow, when ur engine/coolant gets cold again the pressure sucks the coolant in the overflow back into the radiator, so if u dont have an overflow, then it'll just go out and you will keep losing coolant
Exactly what happened to me when I had your symptoms. What it turned out to be was the filler neck tab that the cap "grabs" had been bent up slightly on one side which did not allow the cap to seal. Tapped it down with a rubber mallet and the problem was gone.
well what my problem is, without the overflow, each time i drive it and it gets hot a little goes onto the ground, then the next time i drive it i have that much less fluid therefor the fluid gets hotter and comes back out and that much more leaves the car
