Radiator leaking
  • Thread starter Thread starter glowstang93
  • Start date Start date Dec 5, 2007
glowstang93
20+ Year Stangneter
Feb 9, 2003
853
Illinois
Dec 5, 2007
  • Dec 5, 2007
Noticed a small puddle under the car this morning of antifreeze. Leaking just below the drain valve. Have a radiator ordered will be here tomorrow from O'Reilly's. It is item 433556. Its a regular radiator, nothing fancy. Never had any overheating problems with the stock one, so saw no need to upgrade. Guess 14 yrs and 91,000 miles was pretty good on a stock radiator.
Any helpful hints when it comes to putting the antifreeze back in and making sure there are no air pockets, etc in the system?
I just drove about 15 minutes from work and it was leaking when I got home and even steaming some from the drain side.
bloopbloob
578
Alberta
Dec 6, 2007
  • Dec 6, 2007
fill it up, run it, top it up again. the coolant level will drop when you rev the engine with the cap off, so then rev it and add coolant at the same time. i found this helped get rid of air pockets. i've seen cars with stubborn air pockets, and elevating the front end with ramps or a lift seemed to speed up the process also...
bullitstang1313
713
Indianapolis / Columbus, Indiana
Dec 6, 2007
  • Dec 6, 2007
I usually let it run with the radiator cap off for about 5 minutes or so to try and get the thermostat open and vent the air in the system.
Bossnutt
Dallas Center, Iowa
Dec 6, 2007
  • Dec 6, 2007
When I had to change my thermostat I filled it, let the car run and squeezed the top radiator hose continuously to help it get in the block faster. That helps get the air out as well.
SuperStang83
1,693
Boyertown, Pa
Dec 6, 2007
  • Dec 6, 2007
yeah squeeze the upper radiator hose and keep the cap off while sitting there running it. Keep topping it off, so that you can get all the air bubbles out.
J
jdgt281
20
Florence, Alabama
Dec 6, 2007
  • Dec 6, 2007
You wont have to worrie about air pockets, but i just take cap off start engine fill and wait till thermostat opens then fill and cap off..Done.
bloopbloob
578
Alberta
Dec 7, 2007
  • Dec 7, 2007
not always the case. if the cavities in the engine and system aren't well designed, high points tend to trap gasses, and coolant flow doesn't seem to flush them out. i had to try and fix an overheating old hippy van one time at my old shop, and it would only take about 1/2 the coolant it should. we had to tip it to nearly a 45* angle, and then suddenly it guzzled up what it should have, and all the air came out. there must have been passages that trapped gas no matter how much fluid was flowing by.
squeak93
2,352
418
164
Joplin, Missouri
Dec 7, 2007
  • Dec 7, 2007
I agree, filling up when it drops doesn't always fix the problem. An old fox I used to have took us like 45 minutes of filing when the level dropped, we ended up jacking the car up as well, done the first time. Air pockets are a PITA.
glowstang93
20+ Year Stangneter
Feb 9, 2003
853
Illinois
Dec 11, 2007
  • Dec 11, 2007
Thanks for the help guys. I ended up having my favorite auto shop do the work. Bill wasn't bad at all. $195 all together counting the new radiator and labor. Just didn't have the time or the patience to deal with another repair at this time. I do appreciate the help.
Shakerhood
20+ Year Stangneter
Oct 28, 2004
3,361
211
114
Ohio
Dec 12, 2007
#10
  • Dec 12, 2007
  • #10
Just keep an eye on the Coolant level for the next week or so as it may drop and you may have to top it off.
K
86 GT Water Pump
  • Kade5114
  • May 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 11, 2026
nickyb
D
Engine Coolant and Radio Issues
  • Don7Up
  • Sep 14, 2025
Fox 5.0 Mustang Tech Oct 4, 2025
Don7Up
D
M
2001 v6 heater return pipe leak question
  • mnky99
  • Nov 11, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Nov 11, 2025
mnky99
M
Zero fuel pressure @ Shrader, but over 100 PSI at filter
  • Stang337
  • Jul 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 10, 2025
JD1964
A
2001 Mustang GT, scorched metal smell and noise from trans/diff?
  • AndyE2255
  • Dec 1, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Dec 28, 2025
gkomo
