After having had the experience of money left over after payday (WOW!) I took the Mustang into a local radiator shop and questioned the guy on the cooling problems that periodically plague my baby.
The cooling fan will not run of its own accord - I have to turn on the A/C to engage the fan. As a result, the car will overheat in slow traffic (generally under 35mph for a prolonged period of time). I'd turn on the A/C, but something is wonky about it, which I will address in a seperate thread.
Since I've established that the fan motor runs, that only leaves the relays or the switch. Thanks to a show and tell trip to AutoZone, I now know that a 'fan switch' is actually some small object that fits into one of the lines on my engine which coolant flows through. I'm also led to believe that it is the most common failed component in an electric fan setup.
The radiator guy tells me that my radiator, being the original factory unit, is shot - It definately has leaks, and is most likely internally plugged. This would explain why it won't hold the full 9.4 of coolant/water, and rejects all but 4 quarts regualrly.
He offered me a price of $125 for a 3 row radiator that according to him "has some blemishes on it, but works just fine". I didn't see the radiator he was referring to, and I assume that to mean cosmetic damage only. I have no problem with purely cosmetic damage, but need to know if $125 is a decent price.
He quoted me $60 for installation, but I can do that myself in an afternoon.
Good price? Bad price? Run like hell?
Also if you got a A4LA(auto) then you have two trans cooler lines to unscrew. If you got a T-5 then you can skip this part but the new radiator you buy comes with plugs for the auto lines that should be installed if your car is a T-5 (Stick).
In your name its got III I'm assuming its because you're the third person to be named Raymond?
Its Raymond as well but I like Ray better. When came time to name our son we choose Rhett as in Rhett Butler off, "Gone with the Wind."
I'm sure that applys for everyone including me
I should have been nicer in my reply to you alls post. Sorry
I would take a guess and say the 2.3L radiators are the same from 87-93. My old 85' SVOs look identical to my 93's current new radiator is why I think this.
