VIPERn94Five-0 said:
aww man thanks!
Anthony
VibrantRedGT said:
It's proven-spaghetti style plug wires produce more power.
LOL!!
Reminds me of the time I got the (not so) bright idea to re-route abunch of wires to clean up the engine compartment.... It all went pretty good until I got to that BIG 34 WIRE connector located on the firewall beside the AC condensor (its the connector that has a 10mm bolt holding it together...) Well, I had to splice all 34 wires and lengthen them apx. 3 feet to where I was going to relocate it (inside the passenger side shock tower.) I throughly researched it to see if lengthening the wires (and thus possibly affecting the voltage) would hurt anything... (as long as i used the same gauge wire, or slightly larger, everything should be fine- according to a ford engineer.) Well, i took my good ole' time not to rush this job as I knew that i didn;t want to screw up and get some wires messed up. I
carefully labeled EVERY wire so that after I lengthed everyone, I could make sure it got connected back to its orginal wire. 34 wires, and 34 different color/stripe combinations. Make that
33(!). Thats right. 33. What i didn;t know at the time was that there were TWO gray wires with a yellow stripe
. Do you think *I* got the right two gray wires with a yellow stripe back together right?
Ended up frying the airbag module and it made it run like t total **** (the other wire was somehow connected to the mass air- but no damage was done to it, just the air bag module.) I immediatly knew something was awray when I saw the air bag light warning light continually flashing and the idle was funny. The difficult part was finding what was wrong. I was checking to make sure that all the colors were correct, and they were. I could not for the life of me figure out what the hell was wrong!! Well, fortunately for me, as I was mere moments away from losing my sanity and driving (make that pushing) my heap into the river, I
somehow noticed 2 gray wires with yellow stripes.
Sure enough, one of those wires was ever so slightly smaller than the rest (18 gauge vs 16 gauge for the others.)
So, if anyone else decides to move that beast out of eyesight (it does clean up the back of the firewall) REMEMBER, please REMEMBER there are 2 (two!) gray wires with a yellow stripe!!!
My mess:
