Radiator temperture split
  • Thread starter Thread starter S-Car-Go
  • Start date Start date Sep 18, 2009
S-Car-Go
332
San Jose, CA
Sep 18, 2009
  • Sep 18, 2009
Anyone know what a typical temperature split across a radiator is?
Yesterday in 90* weather my car was running hot. Idling in my driveway, I checked in/out temps and got 225/175. This morning in 60* weather, I had 190/145 when I got to work. Both times ~50*.
The cooling system is 3 row "high efficiancy" radiator from NPD (20"), high volume W/P, 190* standard flow t-stat, shroud and 6 blade flex fan. The motor is a mild 331.
I have a 7 blade fan laying around, so I may try that and see what the delta is. What is the stock temp split for a modern car?
stonecoldtx
214
Dallas, TX
Sep 18, 2009
  • Sep 18, 2009
I'm not sure why the temperature differential would even matter . . . so long as the engine temperature is kept below the boiling point.
That's important, because when it boils, it produces steam, which actually is releasing heat energy, and steam does not have the capacity to transfer the heat of the engine that the liquid coolant does, and therefore, true overheating occurs.
And to increase the boiling point, we have pressurized radiator caps; for every one pound of pressure, the boiling point is raised two degrees.
Therefore, assuming a system with no leaks, with a typical 15lb cap, water would start to boil at 242 degrees.
The important thing is that the heat is being transferred to the coolant by the engine and it's then being transferred from the coolant by the radiator.
The fact that it was running 225 degrees in your driveway idling simply means that there was not sufficient airflow to remove the excess heat from the radiator. It doesn't mean that you need a radiator with a greater temperature differential . . . or a bigger one, for that matter.
If you want to reduce that temperature, use a lower temperature thermostat and ensure that you have sufficient airflow across the radiator; you didn't mention whether you have a fan shroud or not, so I'll assume that you don't.
If indeed you don't, that's a big (and very common) mistake if you're worried about the engine overheating parked or at speed below 35MPH.
The shroud directs all airflow through the radiator so that it can cool more effectively; without the shroud, only the area directly in front of the fan has airflow coming through it when stopped.
So . . . why don't we concentrate on how to improve airflow, and the rest will take care of itself?
2+2GT
3,333
10
79
Southeastern Pennsylvania
Sep 18, 2009
  • Sep 18, 2009
I ran in some new engines this summer, and I was happy with 30°.
S-Car-Go
332
San Jose, CA
Sep 18, 2009
  • Sep 18, 2009
2+2, Thanks.
Stonecold,
I did not say it ran cool at speed. I just gave the temp in my driveway when I got home. I DID say I have a shroud.
Delta-t does give information on what's going on with heat transfer. A high split on a hot motor indicates low water flow, a low split on a hot motor indicates air flow or sizing issues.
Heat transfer is about area, differential and residence time. We do it twice to move heat out of the motor. All things being equal, if 2+2 can cool his car with a 30* split, and mine heats up with a 50* split, I'm not moving enough water. T- stat is not opening enough.
ddonaca351
2,055
Camas Washington
Sep 19, 2009
  • Sep 19, 2009
...make sure you don't have any holes / gaps in the core support around the edge of the radiator.
...make sure the airdam along the bottom of the core support (you know the black part that women seem to think is a curb feeler ) make sure it's not missing or all beat to crap.
...make sure the edge of the fan blades are within 1" (1/2" is better) of the dia of the fanshroud opening. (fans not too small)
...make sure the plane of the fan extends aprox 1" into the back of the fan shroud.
...when you get home (the instant you pull in and stop) get out and lay the back of your hand on the front of the radiator and feel for any cool spots. If you find any, this area of the radiator is plugged / obstructed internally and is not carrying it's load.
...most generic thermostats are a "close enough" operation. If they open within +/- 10 degrees they will probably pass inspection at the factory. Pay $6-$8 more and get a good quality, high flow one from Summit or Jegs or PAW or whoever.
...waterwetter or engine ice or any of a half dozen other products will all enable your coolant to shed the heat quicker and get a larger delta in the same time.
...also dont forget if the coolant is 225 at the radiator, thermostat housing, etc... that means inside the heads and inside the block it's probably right on the ragged edge of steam.
(imho) one of the easiest ways to help, is to give it an electric fan. Hot day, at idle, starting to get warm... nooooo problem, we just flip a switch and viola: 50mph worth of airflow.
And just because one guy gets away with a 30 drop, you may or may not be ok with that. ( maybe he runs a 170 stat and you run a 195, maybe he has a stock 289, you have a 60 over block with a stroker kit, you've got new alloy heads and his are iron 60's rejects with 40 years of scale build up in em, etc... ) too many variables to go black or white on the topic.
S-Car-Go
332
San Jose, CA
Sep 19, 2009
  • Sep 19, 2009
I did all of those items exept water wetter and an electric fan before my first post (and they are all excellent suggestions and good points).
I've used Mr Gasket and Robert Shaw high flow t-stats in the past, but they have too much by-pass when cold (takes forever to warm up). Just the same I tossed in an old 180* hiflow today. I had a cheapie Auto Zoo 180* in it. Next time I order from summit, I'll try a good standard flow t-stat. It's supposed to be 100* in the bay area tomorrow, so we'll see what happens.
Yes, I was hoping for more than one input on the temp split. I got my truck running today (new trans) and checked it as well. It had a 25* delta. Admittedly that is a worse example since it has a cross flow radiator and is very different.
I'm gonna stand by my theroy the water in the mustang was moving too slow. Big delta in the radiator and and staying in the block too long. Then again, it wouldn't be the first time I was wrong.
2+2GT
3,333
10
79
Sep 19, 2009
  • Sep 19, 2009
Do you have a shutoff valve in the heater hose? That'll increase movement of the coolant to the radiator.
S-Car-Go
332
San Jose, CA
Sep 20, 2009
  • Sep 20, 2009
No shut off installed in the heater hose. I do have an after market pump, so it should flow plenty to both.
I'm going to have to consdede the temp split is a synptom, not a cause.
I installed a high flow 180* t-stat and went for a drive in 89* weather. It took forever for the car to reach operating temp, then slowly climed up. Back in the driveway, temps were 220*/175*. It just took longer to get there. Double checked looking for cool spots in the radiator and couldn't find any. Next up, I'll check my timing (doubt it). Then install the 7 blade heavy duty fan.
BTW, I did vary the rpms I was cruising at (1300@55 mph, etc.). Since I couldn't cool it at 65 MPH, I don't think it's an air flow issue.
ddonaca351
2,055
Camas Washington
Sep 24, 2009
  • Sep 24, 2009
This is a reeeeaaallll longshot, but you don't by chance have the heatercore bypassed do you?
( just looped back at the water pump)
Found that the hard way once...
2+2GT
3,333
10
79
Sep 24, 2009
#10
  • Sep 24, 2009
  • #10
Any flow to the heater is wasted. If you don't have AC, then you can put a manual valve in the heater supply hose. If you do have AC, you need the valve anyway.
S-Car-Go
332
San Jose, CA
Sep 27, 2009
#11
  • Sep 27, 2009
  • #11
The heater core is hooked up (I used it when it was running hot).
I do appricate the suggestion about the valve, but I don't think I would like the looks of that in the engine compartment. Plus I use the heater on my way to work.
I drove the car with a 7 blade flex fan and hi flow t-stat and it's fine below 85* , but slowly heats up at 90* or above. I can't find anything wrong with the car or the cooling system. At this point I think this is just the limit of the radiator.
I typically don't drive the car when it's going to be above 85*, so I never noticed this problem before (no A/C, black vinyl interior, top down = cooked driver). I think I'll put the car back to how I had it and go back to not driving it when it really hot.
Thanks for your effort/help.
Engine Themostat
  • Mindseye007
  • Jan 30, 2026
Fox 5.0 Mustang Tech Feb 1, 2026
86HO5.0
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
Engine Engine Bay crazy hot!
  • R82148V
  • Aug 28, 2023
6K
Fox 5.0 Mustang Tech Aug 30, 2023
Mustang5L5
Fox Radiator hose temp vs true coolant temp
  • 93CalypsoConvert
  • Apr 10, 2022
7K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 27, 2022
7991LXnSHO
